NEC X981UHD-2 98" LFD
Quicklinx: CN91WS00 Mfr#: 60004106#WPP
NEC is ushering in a era of visual experience with the 98" X981UHD. The display sets standards in image size and quality with a 98" canvas with UHD (3840 x2160) resolution at full 60Hz. State of the art innovation delivers 24/7 runtimes with high end components and LED backlighting. Ideal for any industrial application, from control rooms to conferencing to life size digital signage.
NEC MultiSync X981UHD-2 X Series - 98" LED-backlit LCD display - 4K - for digital signage / interactive communication
LED-backlit LCD flat panel display
Diagonal Class
98"
Commercial Use
Yes - interactive digital signage
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Input Video Formats
1080i, 1080p, 480/60p, 720/60p, 720/50p, 576/50p, 480/60i, 576/50i
Frame Rate & Enhancement Technology
60 Hz Refresh Rate
Video Interface
HDMI
HDMI Ports Qty
4 ports
LAN, NFC
PC Interface
DVI, DisplayPort
S-IPS
LCD Backlight Technology
Direct-lit LED local dimming
Image Aspect Ratio
16:9
TV Tuner
No tuner
Speaker System
2 speakers
USB
Remote control
Energy Class
Class A
560 Watt
Power Consumption (On mode)
348 W
Power Consumption Stand by
0.5 Watt
Energy Consumption per Year
507 kWh
220.4 cm x 10.8 cm x 125.9 cm
95 kg
3-year warranty
Energy Class
Class A
560 Watt
348 W
507 kWh
Diagonal Class
98"
Commercial Use
Series
X Series
TV Tuner
No tuner
TV Tuner Presence
No
Sensors
Ambient light sensor (ALS), temperature sensor
Video Interface
HDMI
HDMI Ports Qty
4 ports
PC Interface
DVI, DisplayPort
Modes
Portrait mode, landscape mode, Eco mode, Face-up Mode, SpectraView Engine Mode
Dimensions
Without stand
220.4 cm
10.8 cm
125.9 cm
95 kg
Enclosure Colour
Display
LCD Display Technology
S-IPS
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Image Aspect Ratio
16:9
60 Hz Refresh Rate
Direct-lit LED - local dimming
Image Contrast Ratio
1300:1
Brightness
500 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Response Time
8 ms
Certified for 24/7 Continuous Operation, Open Pluggable Specification slot, Carbon Footprint Meter, DICOM support, NaViSet Administrator 2
Stands & Mounts
Stand
Optional
Flat Panel Mount Interface
400 x 400 mm
Video Features
Input Video Formats
Supported Computer Resolutions
1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA), 1280 x 768 (WXGA), 1280 x 1024 (SXGA), 1600 x 1200 (UXGA), 1360 x 768, 1920 x 1080, 3840 x 2160, 4096 x 2160
Media Player
USB Port
Remote Control
Remote control
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
Speakers
2 x main channel speaker - 10 Watt
Network & Internet Multimedia
LAN, NFC
LAN Protocol
Fast Ethernet
Connector Type
DisplayPort input , 4 x HDMI input , 2 x DVI-D input , Audio input , Audio output , 2 x speakers output , Serial input , 2 x LAN , Remote control input , USB 2.0 upstream , USB 2.0 downstream , Service
DisplayPort cable
FCC Class B certified, CSA, UL, TUV GS, VCCI, cUL, VESA DPMS, VESA FDMI, PSB, RoHS, IP40, IP20
Power supply
0.5 Watt
On / Off Switch
Limited warranty - 3 years , Limited warranty - backlight - 3 years
20 - 80%
