NEC is ushering in a era of visual experience with the 98" X981UHD. The display sets standards in image size and quality with a 98" canvas with UHD (3840 x2160) resolution at full 60Hz. State of the art innovation delivers 24/7 runtimes with high end components and LED backlighting. Ideal for any industrial application, from control rooms to conferencing to life size digital signage.
- NEC MultiSync X981UHD-2 X Series - 98" LED-backlit LCD display - 4K - for digital signage / interactive communication
- Product Type
- LED-backlit LCD flat panel display
- Diagonal Class
- 98"
- Commercial Use
- Yes - interactive digital signage
- Black
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- Input Video Formats
- 1080i, 1080p, 480/60p, 720/60p, 720/50p, 576/50p, 480/60i, 576/50i
- Frame Rate & Enhancement Technology
- 60 Hz Refresh Rate
- Video Interface
- HDMI
- HDMI Ports Qty
- 4 ports
- Connectivity
- LAN, NFC
- PC Interface
- DVI, DisplayPort
- Technology
- S-IPS
- LCD Backlight Technology
- Direct-lit LED local dimming
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Speaker System
- 2 speakers
- USB
- Included Accessories
- Remote control
- Energy Class
- Class A
- 560 Watt
- Power Consumption (On mode)
- 348 W
- Power Consumption Stand by
- 0.5 Watt
- Energy Consumption per Year
- 507 kWh
- Dimensions (WxDxH) - without stand
- 220.4 cm x 10.8 cm x 125.9 cm
- 95 kg
- 3-year warranty
- Product Type
- Energy Class
- Class A
- 560 Watt
- 348 W
- 507 kWh
- Diagonal Class
- 98"
- Commercial Use
- Series
- X Series
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Sensors
- Ambient light sensor (ALS), temperature sensor
- Video Interface
- HDMI
- HDMI Ports Qty
- 4 ports
- PC Interface
- DVI, DisplayPort
- Modes
- Portrait mode, landscape mode, Eco mode, Face-up Mode, SpectraView Engine Mode
- Dimensions
- Without stand
- 220.4 cm
- 10.8 cm
- 125.9 cm
- 95 kg
- Enclosure Colour
- Black
Display
- LCD Display Technology
- S-IPS
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- 16:9
- Direct-lit LED - local dimming
- Image Contrast Ratio
- 1300:1
- Brightness
- 500 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Response Time
- 8 ms
- Certified for 24/7 Continuous Operation, Open Pluggable Specification slot, Carbon Footprint Meter, DICOM support, NaViSet Administrator 2
Stands & Mounts
- Stand
- Optional
- Flat Panel Mount Interface
- 400 x 400 mm
Video Features
- Supported Computer Resolutions
- 1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA), 1280 x 768 (WXGA), 1280 x 1024 (SXGA), 1600 x 1200 (UXGA), 1360 x 768, 1920 x 1080, 3840 x 2160, 4096 x 2160
Media Player
- USB Port
Remote Control
- Remote control
Audio System
- Speaker System
- 2 speakers
- Output Power / Total
- 20 Watt
- Speakers
- 2 x main channel speaker - 10 Watt
Network & Internet Multimedia
- Connectivity
- LAN, NFC
- LAN Protocol
- Fast Ethernet
- Connector Type
- DisplayPort input , 4 x HDMI input , 2 x DVI-D input , Audio input , Audio output , 2 x speakers output , Serial input , 2 x LAN , Remote control input , USB 2.0 upstream , USB 2.0 downstream , Service
- Cables Included
- DisplayPort cable
- FCC Class B certified, CSA, UL, TUV GS, VCCI, cUL, VESA DPMS, VESA FDMI, PSB, RoHS, IP40, IP20
- Power Device
- Power supply
- 0.5 Watt
- On / Off Switch
- Limited warranty - 3 years , Limited warranty - backlight - 3 years
- 0 °C
- 40 °C
- 20 - 80%
