NEC X754HB 75" Full HD LED Large Format Display
Quicklinx: CBXBBTBS Mfr#: 60003913
Video Interface: HDMI
TV Tuner Presence: No
£7,457.06 ex VAT
£8,948.47 inc VAT
The LED backlit 75" NEC X754HB offers superior brightness, extended runtimes and advanced engineering necessary for digital signage and messaging in high ambient light applications. This is the ideal display for window-facing retail signage where the sun may directly affect the fidelity of picture quality for a normal television or dimmer display. It can also be used for quick serve restaurant menuboard applications when coupled with a weatherproof type of enclosure. Direct LED backlighting allows for localzed dimming capabilities which greatly enhance the contrast ratio as well as lessen the overall power consumption, Special quarter lambda polarizer is integrated onto the panel of this display that allows for the display to be seen in any type of orientation even when a customer is wearing polarized sunglasses. This display is the ideal solution for installations where high brightness is a necessity.
NEC MultiSync X754HB X Series - 75" LED-backlit LCD display - 1080p (Full HD) - for digital signage
LED-backlit LCD flat panel display
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/428968
Diagonal Class
75"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Input Video Formats
480p, 720p, 1080i, 1080p, 480i, 576i, 576p
Frame Rate & Enhancement Technology
60 Hz Refresh Rate
Video Interface
HDMI
HDMI Ports Qty
1 ports
PC Interface
DVI, VGA (HD-15), DisplayPort
HDCP Compatible
S-PVA
LCD Backlight Technology
Direct-lit LED local dimming
Image Aspect Ratio
16:9
TV Tuner
No tuner
Speaker System
2 speakers
Remote control
Energy Class
Class G
820 Watt
Power Consumption (On mode)
607 W
Power Consumption Stand by
1 Watt
Energy Consumption per Year
735 kWh
169.4 cm x 14.6 cm x 97.2 cm
62 kg
3-year warranty
Energy Class
Class G
820 Watt
607 W
607 kWh/1000h
735 kWh
Diagonal Class
75"
Commercial Use
Series
X Series
TV Tuner
No tuner
TV Tuner Presence
No
Sensors
Ambient light sensor (ALS), temperature sensor, NFC sensor
Video Interface
HDMI
HDMI Ports Qty
1 ports
PC Interface
HDCP Compatible
Modes
Portrait mode, landscape mode, Eco mode
169.4 cm
14.6 cm
97.2 cm
62 kg
Display
LCD Display Technology
S-PVA
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
60 Hz Refresh Rate
Direct-lit LED - local dimming
Image Contrast Ratio
5000:1
Brightness
2500 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Response Time
6 ms
Open Pluggable Specification slot, automatic alarm e-mails, HTTP server, Point Zoom function, sunlight readable
Stands & Mounts
Stand
Optional
Flat Panel Mount Interface
400 x 400 mm
Video Features
Input Video Formats
Supported Computer Resolutions
1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA), 1280 x 768 (WXGA), 1280 x 1024 (SXGA), 1600 x 1200 (UXGA), 1360 x 768, 1920 x 1080, 3840 x 2160, 4096 x 2160
Remote Control
Remote control
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
External Speakers Amplifier Power (Total)
30 Watt
Speakers
2 x main channel speaker - 10 Watt
Connector Type
2 x LAN , USB , Serial , DisplayPort input , DisplayPort output , DVI-D input , VGA input , HDMI input , 2 x audio input , Headphones , Speakers output , Remote control
DVI cable
FCC Class B certified, CSA, UL, TUV GS, VCCI, C-Tick, cUL, VESA DPMS, PSB, RoHS
Power supply
1 Watt
On / Off Switch
Limited warranty - 3 years , Limited warranty - backlight - 3 years
20 - 80%
Brand: NEC
Price Range Ex VAT: £1500+
