NEC X555UNS 55" 1920 x 1080 LED Large Format Display
Quicklinx: CBX6WS00 Mfr#: 60003905
  • 1080p
The ultra slim X555UNS features a 3,5 mm bezel to create impressive high resolution videowalls with barely visible bezels. Connectivity and Sensors allow additional creativity in the content displayed. The unique built-in NFC sensor in combination with NEC's Android app reduces installation and maintenance times, especially useful on larger installations.
The perfect picture quality and high product reliability make the X555UNS an ideal solution for retail signage, control room applications, transport installations and the rental market.
  • Reduced installation and operating costs
    Featuring LED backlight technology the display is highly energy efficient with a low power consumption, longer backlight lifetime and a lighter design for easy and flexible transportation, mounting and integration.
  • Native UHD daisy chaining through DisplayPort 1,2 multi-streaming
    Enables the user to create UHD videowalls with either a single UHD image or 4 different Full HD sources.
  • Auto Tile Matrix
    For a complete auto set up for videowalls. Save time and cost by configuring one display in order to complete the set up for the entire wall.
  • Frame Comp
    Supports a seamless appearance and shows the content without any interruption, creating one stunning image by synchronizing the content across the wall.
  • Reliable color reproduction
    Due to 10-bit color performance with amazing viewing angles and hardware calibratable LUT for accurate image presentation.
  • Unique NEC heat management
    Enables the user to monitor and control the heat inside the display with user controllable fans. Heat management is crucial for larger walls and mission critical installations to secure reliability and longevity.
NEC MultiSync X555UNS X Series - 55" LED-backlit LCD display - Full HD
LED-backlit LCD flat panel display
Diagonal Class
55"
Resolution
1920 x 1080
Display Format
1080p
Frame Rate & Enhancement Technology
60 Hz Refresh Rate
Video Interface
HDMI
HDMI Ports Qty
1 ports
PC Interface
DVI, VGA (HD-15), DisplayPort
HDCP Compatible
IPS
LCD Backlight Technology
WLED backlight - direct-lit LED
Image Aspect Ratio
16:9
TV Tuner
No tuner
Remote control
Energy Class
Class C
310 Watt
Power Consumption Stand by
0.5 Watt
Energy Consumption per Year
225 kWh
121.3 cm x 9.5 cm x 68.4 cm
30.3 kg
Environmental Standards
ENERGY STAR Qualified
3-year warranty
Energy Class
Class C
310 Watt
225 kWh
Diagonal Class
55"
Series
X Series
TV Tuner
No tuner
TV Tuner Presence
No
Sensors
Temperature sensor, NFC sensor
Video Interface
HDMI
HDMI Ports Qty
1 ports
PC Interface
HDCP Compatible
Modes
Eco mode
Dimensions
Without stand
121.3 cm
9.5 cm
68.4 cm
30.3 kg
Enclosure Colour
Display
LCD Display Technology
IPS
Resolution
1920 x 1080
Display Format
1080p
Image Aspect Ratio
16:9
60 Hz Refresh Rate
Image Contrast Ratio
1200:1
Brightness
700 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Response Time
12 ms
TileMatrix, Open Pluggable Specification slot, Carbon Footprint Meter, auto tiling function, automatic alarm e-mails, Frame Comp, HTTP server, Point Zoom function
Stands & Mounts
Stand
Optional
Flat Panel Mount Interface
400 x 400 mm
Video Features
Supported Computer Resolutions
1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA), 1280 x 768 (WXGA), 1280 x 1024 (SXGA), 1600 x 1200 (UXGA), 1360 x 768, 1920 x 1080, 3840 x 2160, 4096 x 2160
Remote Control
Remote control
Audio System
External Speakers Amplifier Power (Total)
30 Watt
Connector Type
2 x LAN , USB , Serial input , DisplayPort input , DisplayPort output , DVI-D input , VGA input , HDMI input , 2 x audio input , Audio output , Speakers output , Remote control input
DisplayPort cable , Network cable
FCC Class B certified, CSA, UL, TUV GS, VCCI, C-Tick, cUL, VESA DPMS, VESA FDMI, PSB, RoHS
Sustainability Information
ENERGY STAR Certified
ENERGY STAR Version
6.0
Power supply
0.5 Watt
On / Off Switch
Limited warranty - 3 years , Limited warranty - backlight - 3 years
20 - 80%
