NEC X551S LCD Display
Quicklinx: 82KGWS00 Mfr#: 60003057#SP
  • 1080p
The superslim MultiSync X551S delivers the longevity and reliability customers expect from a public display thanks to a professional public display panel and proven NEC engineering excellence. The reduced depth and light weight makes it easy to handle and integrate while the slim option slot STv2 allows for the integration of powerful slot-in PCs and other option slot products.
  • Color calibration
    The display can be hardware color calibrated to make sure e.g. customer's logo is displayed accurately.
  • DICOM support
    For medical applications. Programmable ambient light sensor reduces power consumption and eye pleasing brightness levels.
  • Edge LED back light technology
    Thanks to edge LED back light technology the display comes with super slim and light weight design which enables integration in extremely slim cabinets and installations with space constraints.
  • Unique NEC heat management
    Unique NEC heat management enables the user to monitor and control the heat inside the display with user controllable fans. Ideal for heavy duty applications or integration jobs.
  • Slot technology
    Slot technology allows for the integration of single board computers and other option slot products without the need to stow external equipment.
  • Integrated speakers
    Integrated speakers save installation costs and preserve the clean look of the screen.
  • Daisy chaining via DVI
    Daisy chaining via DVI offers high flexibility at no extra cost if the signal needs to be passed on for videowalls or back-to-back installations.
NEC MultiSync X551S 55" LED-backlit LCD display - for digital signage
LED-backlit LCD flat panel display
Diagonal Class
55"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Input Video Formats
1080/24p, 1080/60i, 480/60p, 720/60p, 1080/50i, 720/50p, 576/50p, 1080/50p, 1080/60p, 1080/30p, 1080/25p
Max Number of Screens
100
Video Interface
Composite, HDMI
HDMI Ports Qty
1 ports
PC Interface
DVI, VGA (HD-15), DisplayPort
HDCP Compatible
S-PVA
LCD Backlight Technology
Edge-lit LED
Image Aspect Ratio
16:9
TV Tuner
No tuner
Sound Output Mode
Stereo
Speaker System
2 speakers
Remote control
Voltage
155 Watt
125 cm x 4.3 cm x 72.6 cm
23.9 kg
Environmental Standards
ENERGY STAR Qualified
3-year warranty
155 Watt
Diagonal Class
55"
Commercial Use
TV Tuner
No tuner
TV Tuner Presence
No
Sensors
Ambient light sensor (ALS)
Video Interface
Composite, HDMI
HDMI Ports Qty
1 ports
PC Interface
HDCP Compatible
Cooling System
Fanless
Dimensions
Without stand
125 cm
4.3 cm
72.6 cm
23.9 kg
Enclosure Colour
Display
LCD Display Technology
S-PVA
Resolution
1920 x 1080
Image Aspect Ratio
16:9
Edge-lit LED
Image Contrast Ratio
4000:1
Brightness
600 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Response Time
8 ms
V-Sync Rate at Max Res.
60 Hz
Max V-Sync Rate
85 Hz
Max H-Sync Rate
91.1 kHz
TileMatrix (10 x 10)
Video Wall
100
Stands & Mounts
Flat Panel Mount Interface
300 x 300 mm
Video Features
Input Video Formats
Supported Computer Resolutions
1366 x 768, 1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA), 1280 x 768 (WXGA), 1280 x 1024 (SXGA), 1600 x 1200 (UXGA), 1280 x 960, 1280 x 720, 720 x 400, 1680 x 1050 (WSXGA+), 1920 x 1080, 1280 x 800, 1400 x 1050
Remote Control
Remote control
Audio System
Sound Output Mode
Stereo
Speaker System
2 speakers
Output Power / Total
10 Watt
External Speakers Amplifier Power (Total)
30 Watt
Speakers
2 x speaker - 5 Watt
Connector Type
DisplayPort input , HDMI input , DVI-D input , DVI-D output , VGA input , Composite video input , LAN , Remote control input , Remote control output , Audio input , Audio output , 2 x speakers output
Expansion Slots
1 x Expansion Slot
VGA cable
Plug and Play, FCC Class A certified, CSA, UL, TUV GS, VCCI, C-Tick, cUL, DDC-2Bi, VESA DPMS, VESA FDMI, PSB, DDC/CI, RoHS
ENERGY STAR Certified
ENERGY STAR Version
5.0
Power adapter
Input Voltage
Limited warranty - parts and labour - 3 years
5 °C
20 - 80%
