The ultra slim X464UNV features a very thin bezel to create impressive high resolution videowalls with barely visible bezels. Connectivity and sensors allow additional creativity in the content displayed. The unique built-in NFC sensor in combination with NEC's Android app reduces installation and maintenance times, especially useful on larger installations. The perfect picture quality and high product reliability make the X464UNV an ideal solution for retail signage, control room applications, transport installations and the rental market.
Future ready with OPS cable free expansion
Upgrade the power of your display at any time without the need for external cables or devices. -
Programmable ambient light sensor
For reduced power consumption and eye pleasing brightness levels. -
DICOM support- for medical applications
Reduced installation and operating costs - featuring LED backlight technology the display is highly energy efficient with low power consumption, longer backlight lifetime and a lighter design for easy and flexible transportation, mounting and integration.
- NEC MultiSync X464UNV-2 X Series - 46" LED-backlit LCD display - Full HD - for digital signage
- Product Type
- LED-backlit LCD flat panel display
- Diagonal Class
- 46"
- Commercial Use
- Yes - digital signage
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- Input Video Formats
- 480p, 720p, 1080i, 1080p, 480i, 576i, 576p
- Frame Rate & Enhancement Technology
- 60 Hz Refresh Rate
- Video Interface
- Component, HDMI
- HDMI Ports Qty
- 1 ports
- PC Interface
- DVI, VGA (HD-15), DisplayPort
- HDCP Compatible
- Technology
- S-PVA
- LCD Backlight Technology
- WLED backlight - direct-lit LED
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Speaker System
- Speakers not included
- Voltage
- AC 120/230 V (50/60 Hz)
- Energy Class
- Class A
- 115 Watt
- Power Consumption (On mode)
- 66 W
- Power Consumption Stand by
- 1 Watt
- Energy Consumption per Year
- 96 kWh
- Dimensions (WxDxH) - without stand
- 102.4 cm x 11.73 cm x 57.86 cm
- 24.3 kg
- Environmental Standards
- ENERGY STAR Qualified
- 3-year warranty
- Product Type
- Energy Class
- Class A
- 115 Watt
- 66 W
- 96 kWh
- Diagonal Class
- 46"
- Commercial Use
- Series
- X Series
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Sensors
- Ambient light sensor (ALS), NFC sensor
- Video Interface
- Component, HDMI
- HDMI Ports Qty
- 1 ports
- PC Interface
- HDCP Compatible
- Modes
- Eco mode
- Dimensions
- Without stand
- 102.4 cm
- 11.73 cm
- 57.86 cm
- 24.3 kg
Display
- LCD Display Technology
- S-PVA
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- 16:9
- Image Contrast Ratio
- 3500:1
- Brightness
- 500 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Response Time
- 8 ms
- TileMatrix, Open Pluggable Specification slot, auto tiling function, automatic alarm e-mails, Frame Comp, HTTP server
Stands & Mounts
- Flat Panel Mount Interface
- 300 x 300 mm
Video Features
- Supported Computer Resolutions
- 1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA), 1280 x 768 (WXGA), 1280 x 1024 (SXGA), 1600 x 1200 (UXGA), 1360 x 768, 1920 x 1080, 3840 x 2160, 4096 x 2160
Audio System
- Speaker System
- External Speakers Amplifier Power (Total)
- 30 Watt
- Connector Type
- DVI-D input , HDMI , DisplayPort input , DisplayPort output , VGA input , Remote control input , Serial input , 2 x audio input , 2 x LAN , USB , Audio output , Speakers output
- Cables Included
- DisplayPort cable , Network cable
- VESA DPMS
Sustainability Information
- ENERGY STAR Certified
- ENERGY STAR Version
- 6.0
- Power Device
- Power supply
- Input Voltage
- 1 Watt
- Power Consumption Sleep
- 0.5 Watt
- On / Off Switch
- Limited warranty - 3 years , Limited warranty - backlight - 3 years
- 0 °C
- 40 °C
- 20 - 80%
