NEC X464U64UNV 46" 1920x1080 HDMI DVI-D DisplayPort LCD Display
Quicklinx: CBX1WS00 Mfr#: 60003791
  • 1080p
The ultra slim X464UNV features a very thin bezel to create impressive high resolution videowalls with barely visible bezels. Connectivity and sensors allow additional creativity in the content displayed. The unique built-in NFC sensor in combination with NEC's Android app reduces installation and maintenance times, especially useful on larger installations. The perfect picture quality and high product reliability make the X464UNV an ideal solution for retail signage, control room applications, transport installations and the rental market.
  • Future ready with OPS cable free expansion
    Upgrade the power of your display at any time without the need for external cables or devices.
  • Programmable ambient light sensor
    For reduced power consumption and eye pleasing brightness levels.
  • DICOM support- for medical applications
    Reduced installation and operating costs - featuring LED backlight technology the display is highly energy efficient with low power consumption, longer backlight lifetime and a lighter design for easy and flexible transportation, mounting and integration.
NEC MultiSync X464UNV-2 X Series - 46" LED-backlit LCD display - Full HD - for digital signage
LED-backlit LCD flat panel display
Diagonal Class
46"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p
Input Video Formats
480p, 720p, 1080i, 1080p, 480i, 576i, 576p
Frame Rate & Enhancement Technology
60 Hz Refresh Rate
Video Interface
Component, HDMI
HDMI Ports Qty
1 ports
PC Interface
DVI, VGA (HD-15), DisplayPort
HDCP Compatible
S-PVA
LCD Backlight Technology
WLED backlight - direct-lit LED
Image Aspect Ratio
16:9
TV Tuner
No tuner
Speaker System
Speakers not included
Voltage
Energy Class
Class A
115 Watt
Power Consumption (On mode)
66 W
Power Consumption Stand by
1 Watt
Energy Consumption per Year
96 kWh
102.4 cm x 11.73 cm x 57.86 cm
24.3 kg
Environmental Standards
ENERGY STAR Qualified
3-year warranty
Energy Class
Class A
115 Watt
66 W
96 kWh
Diagonal Class
46"
Commercial Use
Series
X Series
TV Tuner
No tuner
TV Tuner Presence
No
Sensors
Ambient light sensor (ALS), NFC sensor
Video Interface
Component, HDMI
HDMI Ports Qty
1 ports
PC Interface
HDCP Compatible
Modes
Eco mode
Dimensions
Without stand
102.4 cm
11.73 cm
57.86 cm
24.3 kg
Display
LCD Display Technology
S-PVA
Resolution
1920 x 1080
Display Format
1080p
Image Aspect Ratio
16:9
60 Hz Refresh Rate
Image Contrast Ratio
3500:1
Brightness
500 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Response Time
8 ms
TileMatrix, Open Pluggable Specification slot, auto tiling function, automatic alarm e-mails, Frame Comp, HTTP server
Stands & Mounts
Flat Panel Mount Interface
300 x 300 mm
Video Features
Input Video Formats
Supported Computer Resolutions
1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA), 1280 x 768 (WXGA), 1280 x 1024 (SXGA), 1600 x 1200 (UXGA), 1360 x 768, 1920 x 1080, 3840 x 2160, 4096 x 2160
Audio System
Speaker System
External Speakers Amplifier Power (Total)
30 Watt
Connector Type
DVI-D input , HDMI , DisplayPort input , DisplayPort output , VGA input , Remote control input , Serial input , 2 x audio input , 2 x LAN , USB , Audio output , Speakers output
DisplayPort cable , Network cable
VESA DPMS
Sustainability Information
ENERGY STAR Certified
ENERGY STAR Version
6.0
Power supply
Input Voltage
1 Watt
Power Consumption Sleep
0.5 Watt
On / Off Switch
Limited warranty - 3 years , Limited warranty - backlight - 3 years
20 - 80%
