NEC's 80" V801 commercial-grade large-screen LCD display is ideal for applications requiring considerable screen size such as education facilities, coporate lobbies, board rooms, and retail. This display utilizes LED-backlighting to deliver a slim depth and low power consumption while a full high-definition panel delivers brilliant imagery.
- NEC MultiSync V801 V Series - 80" LED-backlit LCD display - for digital signage
- Product Type
- LED-backlit LCD flat panel display
- Diagonal Class
- 80"
- Commercial Use
- Yes - digital signage
- Black
- Resolution
- 1920 x 1080
- Max Number of Screens
- 100
- Video Interface
- Component, composite, HDMI
- HDMI Ports Qty
- 1 ports
- PC Interface
- DVI, VGA (HD-15), DisplayPort
- HDCP Compatible
- LCD Backlight Technology
- Edge-lit LED
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Picture Enhancements
- DICOM Simulated Gamma
- Speaker System
- 2 speakers
- Included Accessories
- Remote control
- Microsoft Certification
- Compatible with Windows 7
- Energy Class
- Class A
- Power Consumption (On mode)
- 212 W
- Power Consumption Stand by
- 1 Watt
- Energy Consumption per Year
- 310 kWh
- 60 kg
- 3-year warranty
- Product Type
- Energy Class
- Class A
- 212 W
- 310 kWh
- Diagonal Class
- 80"
- Commercial Use
- Series
- V Series
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Sensors
- Ambient light sensor (ALS)
- Video Interface
- HDMI Ports Qty
- 1 ports
- PC Interface
- HDCP Compatible
- Modes
- Eco mode
- Cooling System
- Fanless
- Dimensions
- Without stand
- 60 kg
- Enclosure Colour
- Black
Display
- Resolution
- 1920 x 1080
- 16:9
- Edge-lit LED
- Image Contrast Ratio
- 5000:1
- Brightness
- 320 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Response Time
- 8 ms
- Scheduler Function (with RTC), TileMatrix (10 x 10), Open Pluggable Specification slot
Video Wall
- 100
Remote Control
- Remote control
Audio System
- Speaker System
- 2 speakers
- Output Power / Total
- 20 Watt
- External Speakers Amplifier Power (Total)
- 30 Watt
- Speakers
- 2 x main channel speaker - 10 Watt
- Connector Type
- VGA input , Composite video input , Component video / RGB input , DVI-D input , DVI-D output , HDMI , DisplayPort , Audio input , Remote control , Serial input , LAN , Serial output
- Cables Included
- DVI cable
- FCC Class B certified, CSA, UL, TUV GS, VCCI, C-Tick, cUL, VESA DPMS, VESA FDMI, PSB, RoHS
- 1 Watt
- On / Off Switch
- Limited warranty - 3 years , Limited warranty - backlight - 3 years
- 5 °C
- 40 °C
- 20 - 80%
