NEC V463 46" LCD LED Display Full HD 2 x 10W Speakers Black Bezel
Quicklinx: 8N1KWS00 Mfr#: 60003394
  • 1080p
MultiSync V463 is one of the first public displays to feature a professional LCD panel with edge LED backlights. Thanks to this backlight technology, power consumption, weight and depth could be further reduced from the mark set by its predecessor. This generation of V series allows for the seamless integration of various PC boards, HDSDI interfaces and other OPS compatible products.
NEC MultiSync V463 V Series - 46" LED-backlit LCD display
LED-backlit LCD flat panel display
Diagonal Class
46"
Resolution
1920 x 1080
Input Video Formats
1080/24p, 1080/60i, 480/60p, 720/50p, 576/50p, 1080/50p, 1080/60p, 1080/30p, 1080/25p
Max Number of Screens
100
Video Interface
Composite, HDMI, S-Video
HDMI Ports Qty
1 ports
LAN
PC Interface
DVI, VGA (HD-15), DisplayPort
HDCP Compatible
LCD Backlight Technology
Edge-lit LED
Image Aspect Ratio
16:9
TV Tuner
No tuner
Picture Enhancements
DICOM Simulated Gamma
Speaker System
2 speakers
Remote control
Microsoft Certification
Compatible with Windows 7
Energy Class
Class A
Power Consumption (On mode)
79 W
Power Consumption Stand by
0.5 Watt
Energy Consumption per Year
117 kWh
Environmental Standards
ENERGY STAR Qualified
3-year warranty
Energy Class
Class A
79 W
117 kWh
Diagonal Class
46"
Series
V Series
TV Tuner
No tuner
TV Tuner Presence
No
Video Interface
HDMI Ports Qty
1 ports
PC Interface
HDCP Compatible
Cooling System
Fanless
Enclosure Colour
Display
Resolution
1920 x 1080
Image Aspect Ratio
16:9
Edge-lit LED
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Response Time
8 ms
TileMatrix (10 x 10), Open Pluggable Specification slot
Video Wall
100
Stands & Mounts
Stand
Optional
Stand Design
Tabletop
Flat Panel Mount Interface
300 x 300 mm
Video Features
Input Video Formats
Supported Computer Resolutions
1366 x 768, 1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA), 1280 x 768 (WXGA), 1280 x 1024 (SXGA), 1600 x 1200 (UXGA), 1280 x 960, 1280 x 720, 720 x 400, 1680 x 1050 (WSXGA+), 1920 x 1080, 1280 x 800, 1400 x 1050, 720 x 576
Remote Control
Remote control
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
External Speakers Amplifier Power (Total)
30 Watt
Speakers
2 x main channel speaker - 10 Watt
Network & Internet Multimedia
LAN
Connector Type
VGA input , S-Video input , Composite video input , DVI-D input , HDMI , DisplayPort input , 2 x audio input , Audio input , Remote control input , LAN , Serial input , DVI-D output , Audio output , Remote control output , Serial output
VGA cable
FCC Class B certified, CSA, UL, TUV GS, VCCI, C-Tick, cUL, DDC-2Bi, VESA DPMS, VESA FDMI, PSB, RoHS
Sustainability Information
ENERGY STAR Certified
ENERGY STAR Version
5.1
0.5 Watt
On / Off Switch
Limited warranty - 3 years , Limited warranty - backlight - 3 years
5 °C
20 - 80% (non-condensing)
