NEC's 42" V423-TM touch integrated large-screen LCD display offers digital signage users touchscreen capabilities at a cost-conscious price. This display also utilizes LED-backlighting to minimize depth and power consumption. Within the V423-TM bezel is an integrated, low-profile, 4-camera optical-imaging technology that allows for up to six simultaneous touches. Its anti-reflective glass coating protects the panel and allows for higher brightness transmittance. The touchscreen, high-performance panel and abundant advanced technologies promote extended use, making the V423-TM ideal for corporate, retail, restaurant and way finding kiosks.
- NEC MultiSync V423-TM V Series - 42" LED-backlit LCD display
- Product Type
- LED-backlit LCD flat panel display with touchscreen
- Diagonal Class
- 42"
- Black
- Resolution
- 1920 x 1080
- Input Video Formats
- 1080/24p, 1080/60i, 480/60p, 720/60p, 1080/50i, 720/50p, 576/50p, 1080/50p, 1080/60p, 1080/30p, 1080/25p
- Max Number of Screens
- 100
- Video Interface
- Component, composite, HDMI
- HDMI Ports Qty
- 1 ports
- Connectivity
- LAN
- PC Interface
- DVI, VGA (HD-15), DisplayPort
- HDCP Compatible
- Technology
- S-IPS
- LCD Backlight Technology
- Edge-lit LED
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Picture Enhancements
- DICOM Simulated Gamma
- Speaker System
- 2 speakers
- Included Accessories
- Remote control
- Microsoft Certification
- Compatible with Windows 7
- Voltage
- AC 120/230 V (50/60 Hz)
- Energy Class
- Class B
- 360 Watt
- Power Consumption (On mode)
- 85 W
- Power Consumption Stand by
- 0.5 Watt
- Energy Consumption per Year
- 124 kWh
- Dimensions (WxDxH) - without stand
- 100.8 cm x 8.33 cm x 60.1 cm
- 24.4 kg
- 3-year warranty
- Product Type
- Energy Class
- Class B
- 360 Watt
- 85 W
- 124 kWh
- Diagonal Class
- 42"
- Combined With
- Touchscreen
- Series
- V Series
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Sensors
- Ambient light sensor (ALS)
- Video Interface
- HDMI Ports Qty
- 1 ports
- PC Interface
- HDCP Compatible
- Modes
- Portrait mode, landscape mode, Eco mode
- Protection
- Protection glass
- Cooling System
- Fanless
- Dimensions
- Without stand
- 100.8 cm
- 8.33 cm
- 60.1 cm
- 24.4 kg
- Enclosure Colour
- Black
Display
- LCD Display Technology
- S-IPS
- Resolution
- 1920 x 1080
- 16:9
- Edge-lit LED
- Coating
- Anti-reflection
- Image Contrast Ratio
- 1300:1
- Brightness
- 430 cd/m²
- Viewing Angle
- 87°
- Viewing Angle (Vertical)
- 87°
- Touchpoints Qty
- 5
- Response Time
- 12 ms
- TileMatrix (10 x 10), Multitouch, Aspect ratio control (ARC), Optical Touch technology, Open Pluggable Specification slot
Video Wall
- 100
Stands & Mounts
- Stand
- Optional
- Flat Panel Mount Interface
- 300 x 300 mm
Video Features
- Supported Computer Resolutions
- 1366 x 768, 1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA), 1280 x 768 (WXGA), 1280 x 1024 (SXGA), 1600 x 1200 (UXGA), 1280 x 960, 1280 x 720, 720 x 400, 1680 x 1050 (WSXGA+), 1920 x 1080, 1280 x 800, 1400 x 1050, 720 x 576
Remote Control
- Remote control
Audio System
- Speaker System
- 2 speakers
- Output Power / Total
- 20 Watt
- External Speakers Amplifier Power (Total)
- 30 Watt
- Speakers
- 2 x main channel speaker - 10 Watt
Network & Internet Multimedia
- Connectivity
- LAN
- Connector Type
- DisplayPort input , HDMI input , DVI-D input , DVI-D output , Component video / composite video / VGA input , Composite video input , LAN , Serial input , Serial output , Remote control input , 2 x speakers output , Audio input , Audio output
- Cables Included
- VGA cable , USB cable , DVI cable
- FCC Class B certified, CSA, UL, TUV GS, VCCI, C-Tick, cUL, VESA DPMS, PSB, RoHS
- Power Device
- Power supply
- Input Voltage
- 0.5 Watt
- Limited warranty - 3 years , Limited warranty - backlight - 3 years
- 0 °C
- 35 °C
- 20 - 80%
