NEC V323-2 32" Public Display 1920x1080  450cd/m2  1300
Quicklinx: BWYDWS00 Mfr#: 60003849
  • 1080p
NEC's 32" V323-2 high-performance large-screen display utilizes LED backlighting to deliver both environmental and functional benefits for digital signage. The V323-2's commercial-grade panel is capable of displaying brilliant imagery and capturing the audience's attention. This full HD model features a mechanical design as well as an Open Pluggable Specification (OPS)-compliant expansion slot, which future-proofs the display and allows for the seamless integration of a computer or other NEC/third-party component. Because video, RS-232 control and power are passed internally from the display to the computer, additional cabling is not required, thereby simplifying installations. With integrated temperature sensors and fans, this display is ideal in applications that require extended use, including retail stores, restaurants, indoor venues, training facilities and airports.
  • Enhanced connectivity
    With a variety of inputs including DVI-D, VGA, HDMI, and DisplayPort, along with additional audio and LAN connections, this display offers flexibility for integrating into any digital signage setup.
  • Crisp visual performance
    Featuring a 32-inch LED-backlit LCD panel with Full HD 1920 x 1080 resolution, the NEC MultiSync V323-2 delivers stunning image clarity and color accuracy. The edge-lit LED technology ensures consistent brightness and energy efficiency.
  • Optimized for digital signage
    Designed specifically for commercial use, this display includes features like an Open Pluggable Specification slot, Scheduler Function with RTC, and TileMatrix support for up to 100 screens, making it ideal for creating large-scale digital signage solutions.
  • Smart power management
    The NEC MultiSync V323-2 is equipped with an eco mode and an ambient light sensor that adjusts the screen brightness according to the surrounding light, reducing power consumption and extending the display's lifespan.
  • Robust design and compatibility
    This display is built to withstand the demands of continuous operation in public spaces. It's compatible with Windows 7 and adheres to VESA DPMS standards for easy integration into existing systems.
NEC MultiSync V323-2 V Series - 32" Class (31.5" viewable) LED-backlit LCD display - for digital signage
LED-backlit LCD flat panel display
Diagonal Class
32"
Diagonal Size
31.5"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Input Video Formats
1080/24p, 1080/60i, 480/60p, 720/50p, 576/50p, 1080/50p, 1080/60p, 1080/30p, 1080/25p
Frame Rate & Enhancement Technology
60 Hz Refresh Rate
Max Number of Screens
100
Video Interface
HDMI
HDMI Ports Qty
1 ports
PC Interface
DVI, VGA (HD-15), DisplayPort
HDCP Compatible
S-IPS
LCD Backlight Technology
Edge-lit LED
Image Aspect Ratio
16:9
TV Tuner
No tuner
Speaker System
2 speakers
Remote control
Microsoft Certification
Compatible with Windows 7
Voltage
Energy Class
Class B
155 Watt
Power Consumption (On mode)
49 W
Power Consumption Stand by
1 Watt
Energy Consumption per Year
72 kWh
75 cm x 6 cm x 44.4 cm
3-year warranty
Energy Class
Class B
155 Watt
49 W
72 kWh
Diagonal Class
32"
Diagonal Size
31.5"
Commercial Use
Series
V Series
TV Tuner
No tuner
TV Tuner Presence
No
Sensors
Ambient light sensor (ALS)
Video Interface
HDMI
HDMI Ports Qty
1 ports
PC Interface
HDCP Compatible
Modes
Eco mode
Cooling System
Fanless
Dimensions
Without stand
75 cm
6 cm
44.4 cm
Enclosure Colour
Display
LCD Display Technology
S-IPS
Resolution
1920 x 1080
Image Aspect Ratio
16:9
60 Hz Refresh Rate
Edge-lit LED
Image Contrast Ratio
1300:1
Brightness
450 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Response Time
8 ms
NaViSet, Scheduler Function (with RTC), TileMatrix (10 x 10), Open Pluggable Specification slot
Video Wall
100
Stands & Mounts
Stand
Optional
Flat Panel Mount Interface
200 x 200 mm
Video Features
Input Video Formats
Supported Computer Resolutions
1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA), 832 x 624, 1280 x 768 (WXGA), 1280 x 1024 (SXGA), 1600 x 1200 (UXGA), 720 x 400, 1360 x 768, 640 x 400, 1920 x 1080
Remote Control
Remote control
Audio System
Speaker System
2 speakers
Output Power / Total
16 Watt
Speakers
2 x main channel speaker - 8 Watt
Connector Type
DVI-D output , VGA input , DVI-D input , HDMI input , DisplayPort input , Audio input , LAN , Remote control input , Serial input , Audio output , Serial output
FCC Class B certified, CSA, UL, TUV GS, VCCI, C-Tick, BSMI, cUL, DDC-2Bi, SASO, TUV S, VESA DPMS, VESA FDMI, PSB, KCC, KC, EAC
Power supply
Input Voltage
1 Watt
Power Consumption Sleep
0.5 Watt
On / Off Switch
Limited warranty - 3 years , Limited warranty - backlight - 3 years
20 - 80%
