The NEC V302H with a native 1080p resolution is designed to provide higher brightness for classrooms, meeting and conference rooms that have heavy ambient light but require a small projector. This 3000-lumen lightweight mobile model is 3D Ready and includes a 8W speaker, closed captioning and horizontal & vertical keystone correction. Enhanced connectivity, including dual HDMI, computer, composite inputs and RJ45, are clearly color-coded and labeled on the panel.
1080p native resolution
High resolution provides detailed display of text, graphics and images. HD video is displayed in 16:9 wide aspect ratio. -
AutoSense
Intuitively syncs the projector with most computer signals and features one-touch image optimization. -
BrilliantColor
Advanced video processing from Texas Instruments delivers exceptional picture management control for both progressive and interlaced sources, while making images more vibrant, colors more realistic and blacks richer with detail. -
Built-in wall color correction
Presets provide for adaptive color tone correction to display properly on non-white surfaces. -
Carbon savings meter
Calculates the positive effects of operating the projector in ECO Mode, which is encouraged by an optional message at startup. A green Eco mode button on the remote control makes the switch easy. -
Crestron roomview
Provides unified management, including the ability to switch the power on and off for multiple projectors connected to a network.
- NEC V302H - DLP projector - portable - 3D
- DLP projector - 1080p
- 3D Capable
- Built-in Devices
- Speaker
- Microdisplay
- DMD Chip
- Brightness
- 3000 ANSI lumens
- Contrast Ratio
- 8000:1
- Resolution
- Full HD (1920 x 1080)
- Native Aspect Ratio
- 16:9
- Bulb type
- 218 Watt
- Bulb life cycle
- Up to 3500 hour(s) - normal mode , Up to 6000 hour(s) - economic mode
- Video Input
- RGB, composite video, component video (NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60)
- Speakers
- Speaker(s) - internal
- Power
- AC 120/230 V (50/60 Hz)
- 266 Watt
- 32.4 cm x 25 cm x 8.8 cm
- 2.9 kg
- 3-year warranty
- 3D Capable
- Built-in Devices
- Speaker
Projector
- Microdisplay
- DMD Chip
- Brightness
- 3000 ANSI lumens
- Contrast Ratio
- 8000:1
- Image Size
- 102 cm - 762 cm
- Projection Distance
- 1.3 m - 12 m
- Throw Ratio
- 1.5 - 1.8:1
- Resolution
- Full HD - Full HD (1920 x 1080)
- 16:9
- Max Sync Rate (V x H)
- 120 Hz x 100 kHz
- Bulb type
- 218 Watt
- Bulb life cycle
- Controls & Adjustments
- Keystone correction
- Eco-Mode technology, 6-segment colour wheel, BrilliantColor, VIDI Lighting Technology, Crestron RoomView, Direct Power Off, MHL compliance, auto power on, Carbon Savings Meter, Virtual Remote, sleep timer
Lens
- Focus Type
- Manual
- Zoom Type
- Manual
- Keystone Correction Direction
- Vertical
- Vertical Keystone Correction
- -40 / +40
Video Input
- TV System
- NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, composite video, MHL
Speakers
- Internal
- Sound Output Mode
- Mono
- Output Power / Channel
- 8 Watt
- Speakers
- 1 x mixed channel
- 1 x VGA / component video input - 15 pin HD D-Sub (HD-15) , 1 x HDMI input - 19 pin HDMI Type A , 1 x composite video input - RCA , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x serial RS-232 - 9 pin D-Sub (DB-9) , 1 x network - RJ-45 , 1 x audio line-in - RCA x 2 , 1 x Mobile High-Definition Link (MHL) / HDMI - 19 pin HDMI Type A , 1 x USB - mini-USB Type B (management)
- Included Accessories
- Lens cover
- Cables Included
- 1 x VGA cable - VGA to VGA - 1.8 m
- Security Features
- Plug and Play, TUV GS, RoHS, WEEE, ERP
- Power Source
- AC
- Voltage Required
- 266 Watt
- Power Consumption Stand by
- 0.5 Watt
- 32.4 cm
- 25 cm
- 8.8 cm
- 2.9 kg
- E-mail database update - 3 years , Limited warranty - lamp - 6 months / 1000 hours
