NEC V260X DLP 3D Ready XGA Projector - 2600 ANSI Lumens
Quicklinx: 7HWHWS00 Mfr#: 60003178
  • High-Definition Multimedia Interface (HDMI)
Get the ultimate 3D experience with a 3D ready DLP projector from NEC. DLP-Link technology allows 3D images to be projected with the aid of a single projector and active glasses without special screens, filters or emitters. The impression of 3D is created by the interaction with the active LCD shutter glasses. The easy to set up alternative to traditional 3D stereo projection! It's an ideal solution for classrooms, (small) meeting rooms, cross-use (private/professional), mobile/cooperative applications.
NEC V260X - DLP projector - portable - 3D
DLP projector
3D Capable
Built-in Devices
Speaker
Brightness
2600 lumens
Contrast Ratio
2000:1
Resolution
XGA (1024 x 768)
Native Aspect Ratio
4:3
Bulb type
180 Watt
Bulb life cycle
Up to 3000 hour(s) - normal mode , Up to 5000 hour(s) - economic mode
Video Input
RGB, S-Video, composite video (NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60)
Digital Video Standard
Speakers
Speaker(s) - internal
233 Watt
31 cm x 9.5 cm x 24.7 cm
2.5 kg
3-year warranty
DLP projector
3D Capable
Built-in Devices
Speaker
Projector
Brightness
2600 lumens
Contrast Ratio
2000:1
Image Size
76 cm - 762 cm
Projection Distance
1.2 m - 13 m
Throw Ratio
1.95 - 2.15:1
Resolution
XGA - XGA (1024 x 768) (native) / 1920 x 1080 (resized)
Native Aspect Ratio
4:3
Max Sync Rate (V x H)
120 Hz x 100 kHz
Bulb type
180 Watt
Bulb life cycle
Controls & Adjustments
Aspect control
Eco-Mode technology, 6-segment colour wheel, wall colour correction, BrilliantColor, DLP 3D Ready, VIDI Lighting Technology, Crestron RoomView
Lens
Focus Type
Manual
Zoom Type
Manual
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-40 / +40
Video Input
TV System
Analogue video Signal
Video Interfaces
VGA, HDMI, composite video, S-Video
Speakers
Internal
Sound Output Mode
Mono
Output Power / Channel
7 Watt
Speakers
1 x mixed channel
2 x VGA / component video input - 15 pin HD D-Sub (HD-15) , 1 x HDMI input - 19 pin HDMI Type A , 1 x composite video input - RCA , 2 x audio line-in - mini-phone 3.5 mm , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x audio line-out - mini-phone 3.5 mm , 1 x remote control - 9 pin D-Sub (DB-9) , 1 x remote control - RJ-45 , 1 x S-video input - 4 pin mini-DIN , 1 x audio line-out - RCA x 2
Lens cover, wireless remote control
1 x VGA cable - 1.8 m
Security Features
TUV GS, RoHS, ErP Ready
233 Watt
Power Consumption Operational (Standby)
0.5 Watt
31 cm
9.5 cm
24.7 cm
2.5 kg
Limited warranty - 3 years , Limited warranty - lamp - 6 months / 1000 hours
Sound Emission
34 dB
31 dB
