NEC UM280X XGA UST 2800 lumens Projector
Quicklinx: 8JHRWS00 Mfr#: 60003391
Get great performance while saving the environment. Advanced eco features help to substantially lower your operating cost without compromising on quality and flexibility. Less shadow and glare gives the presenter more space to engage with his audience and enhances the experience with interactive white boards.
The UM280X is particularly suited for classrooms and small to medium sized meeting rooms.
  • Enhanced connectivity
    With a wide array of interface options including HDMI, VGA, composite video, and S-video input, this projector ensures seamless connection to a variety of multimedia devices. The inclusion of both USB 2.0 and audio line-in/out ports further enhances its versatility, making it an ideal solution for diverse presentation needs.
  • Superior audiovisual experience
    Boasting a brightness of 2800 lumens and a contrast ratio of 3000:1, the NEC UM280X delivers vivid and sharp images even in well-lit environments. Coupled with an internal 16 watts speaker, it provides an immersive audiovisual experience that is perfect for presentations and multimedia applications.
  • Eco-friendly operation
    Equipped with Eco-Mode technology, Intelligent Power Management, and a lamp life cycle of up to 8000 hours in economic mode, this projector not only reduces energy consumption but also minimizes lamp replacement costs, making it an environmentally friendly and cost-effective choice for businesses and educational institutions.
  • Advanced imaging technology
    The projector features Micro Lens Array (MLA) Technology and a built-in test pattern, ensuring sharp and precise images. The wall color correction feature allows for optimal image projection on surfaces of various colors, making it adaptable to different room settings and enhancing overall presentation quality.
  • Reliable and secure
    Designed with security in mind, the NEC UM280X includes features such as keypad lock, password protection, and a security bar. These features ensure that the projector is safeguarded against unauthorized use, providing peace of mind for users in shared or public environments.
NEC UM280X - LCD projector - ultra short-throw - LAN
LCD projector
Brightness
2800 lumens
Contrast Ratio
3000:1
Resolution
XGA (1024 x 768)
Native Aspect Ratio
4:3
Lens
Ultra short-throw lens
Bulb type
230 Watt
Bulb life cycle
Up to 5000 hours - normal mode , Up to 8000 hours - economic mode
Video Input
RGB, S-Video, composite video (NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60, NTSC 3.58), LAN
Speakers
Speaker(s) - internal
AC 120/230 V (50 - 60 Hz)
304 Watt
37.8 cm x 42.8 cm x 11.2 cm
5.2 kg
3-year warranty
LCD projector
Projector
Brightness
2800 lumens
Contrast Ratio
3000:1
Image Size
152.4 cm - 279.4 cm
Projection Distance
0.6 m - 1.1 m
Throw Ratio
0.36:1
Digital Zoom Factor
1.4x
Resolution
XGA - XGA (1024 x 768) (native) / 1920 x 1080 (resized)
Native Aspect Ratio
4:3
Max Sync Rate (V x H)
120 Hz x 100 kHz
Bulb type
230 Watt
Bulb life cycle
Controls & Adjustments
Off timer
Eco-Mode technology, Color Management System, Micro Lens Array (MLA) Technology, wall colour correction, USB host function, PJlink, Crestron RoomView, Intelligent Power Management, DICOM Simulation Mode, Direct Power Off, Auto Power Off, built-in test pattern
Lens
Focus Type
Manual
Lens Aperture
F/1.8
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-10 / +10
Video Input
TV System
Analogue video Signal
Video Interfaces
VGA, HDMI, composite video, S-Video
LAN and Wireless Image Transferring Protocols
Wired LAN
Speakers
Internal
Sound Output Mode
Mono
Output Power / Channel
16 Watt
Speakers
1 x mixed channel
1 x VGA / component video input - 15 pin HD D-Sub (HD-15) , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 2 x HDMI input - 19 pin HDMI Type A , 1 x composite video input - RCA , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x microphone input - mini-phone 3.5 mm , 1 x audio line-in - RCA x 2 , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x management - 9 pin D-Sub (DB-9) , 1 x network - RJ-45 , 1 x USB - 4 pin USB Type B , 2 x USB 2.0 - 4 pin USB Type A , 1 x S-video input - 4 pin mini-DIN
Remote control
1 x VGA cable
Mounting Kit
Included
Security Features
Security lock slot (cable lock sold separately), password protection, security bar, security label, keypad lock
TUV GS, RoHS, GOST-R, ERP
304 Watt
Power Consumption Operational (Standby)
0.4 Watt
37.8 cm
42.8 cm
11.2 cm
5.2 kg
EMEA warranty - 3 years , EMEA warranty - lamp - 6 months / 1000 hours
5 °C
20 - 80% (non-condensing)
Sound Emission
35 dB
28 dB
