NEC U260W WXGA Ultra Short Throw DLP 3D Ready Projector - 2600 ANSI Lumens
IDEAL SOLUTION FOR BOTH SCHOOLS AND BUSINESSES!
Quicklinx: 7H2VWS00 Mfr#: 60003139
Projectors with almost no shadow and glare greatly improve the use of interactive whiteboards in schools. Enjoy premium space due to widescreen format and play video content in native aspect ratio. The integrated 3D capability makes you ready for the next step towards the digital classroom. Peace of mind also with regards to the delivery of content is ensured by a large variety of analog and digital inputs. For mobile use on a cart the projector can also be used in desktop mode. The projector comes with an easy to install wall-mount to ensure the quality of the installation and offers compatibility to various height-adjustable solutions. It is an ideal solution for educational and business use.
  • Almost no shadow and glare
    Thanks to ultra-short throwing distance, it features almost no shadow and glare.
  • Wall-mount included
    Wall-mount is included for quick and easy installation, compatible with height adjustable systems.
  • Free tilting
    Free tilting is designed for desktop use as well as ceiling and floor projection.
  • Great connectivity
    Due to numerous analog and digital connection terminals as well as network capability, it features great connectivity.
  • Wide format
    Wide format is designed for extra space in presentations and video content in native aspect ratio - no quality loss due to format scaling.
NEC U260W - DLP projector - 3D
DLP projector - 720p
3D Capable
Built-in Devices
Speaker
Brightness
2600 lumens
Contrast Ratio
1800:1
Resolution
WXGA (1280 x 800)
Native Aspect Ratio
16:10
Bulb type
230 Watt
Bulb life cycle
Up to 2500 hour(s) - normal mode , Up to 4000 hour(s) - economic mode
Video Input
RGB, S-Video, composite video, component video (NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60)
Video Output
RGB
Speakers
Speaker(s) - integrated
300 Watt
32.7 cm x 39.3 cm x 13.9 cm
6 kg
3-year warranty
3D Capable
Built-in Devices
Speaker
Projector
Brightness
2600 lumens
Contrast Ratio
1800:1
Image Size
196 cm - 254 cm
Projection Distance
0.13 m - 0.314 m
Throw Ratio
0.3:1
Resolution
WXGA - WXGA (1280 x 800) (native) / 1600 x 1200 (resized)
Native Aspect Ratio
16:10
Max Sync Rate (V x H)
85 Hz x 91.1 kHz
Bulb type
230 Watt
Bulb life cycle
Controls & Adjustments
Keystone correction
6-segment colour wheel, wall colour correction, BrilliantColor, DLP 3D Ready, VIDI Lighting Technology
Lens
Zoom Type
Manual
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-15 / +15
Video Input
TV System
Analogue video Signal
Video Interfaces
VGA, HDMI, composite video, S-Video
Video Output
Analogue Video Signal
RGB
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
10 Watt
Input Device
External
1 x VGA / component video input - 15 pin D-Sub (DB-15) , 1 x VGA output - 15 pin D-Sub (DB-15) , 1 x composite video input - RCA , 1 x HDMI input , 1 x S-video input - 4 pin mini-DIN , 2 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-in - RCA , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x serial RS-232 - 9 pin D-Sub (DB-9) (management) , 1 x network - RJ-45 (management)
Wall mounting kit, remote control
1 x VGA cable - 3 m
Security Features
Plug and Play, TUV GS, RoHS, EuP Ready
300 Watt
Power Consumption Operational (Standby)
0.5 Watt
32.7 cm
39.3 cm
13.9 cm
6 kg
EMEA warranty - 3 years , EMEA warranty - lamp - 6 months / 1000 hours
5 °C
35 °C
20 - 80%
Sound Emission
33 dB
29 dB
