NEC Replacement Lamp for UM330X/UM330W
Quicklinx: 9W0BWS00 Mfr#: 100013230
£479.63 ex VAT
£575.55 inc VAT
Replacement lamp that serves for select NEC ultra-short throw projectors.
  • Enhanced visibility
    The NEC Ultra Short Throw NP17LP-UM projector lamp ensures your presentations are vivid and bright, enhancing visibility in various lighting conditions.
  • Seamless compatibility
    Designed specifically for compatibility with PC systems, this projector lamp integrates seamlessly, ensuring smooth and efficient operation for all your presentation needs.
NEC Ultra Short Throw NP17LP-UM - projector lamp
Projector lamp
1-year warranty
NEC UM330W, UM330Wi, UM330X, UM330Xi
Projector lamp
Limited warranty - 1 year
Type: Projector lamp
Brand: NEC
