NEC Replacement Lamp for PA522U/PA572W/PA671W
Quicklinx: 9W0NWS00 Mfr#: 100013748
£302.30 ex VAT
£362.76 inc VAT
Marketing description is not available.
  • Enhanced brightness
    This projector lamp is designed to enhance the brightness of your presentations and visuals, ensuring clear and vivid images even in well-lit rooms
  • Seamless compatibility
    Specially crafted for compatibility with PC, this projector lamp integrates smoothly with your existing setup, offering a hassle-free upgrade or replacement solution
NEC NP26LP - projector lamp
Projector lamp
NEC NP-PA622U, PA672W, PA722X
Projector lamp
Type: Projector lamp
Brand: NEC
