NEC Replacement lamp for P401W; P451W; P451X; P501X
Quicklinx: 9RYCWS00 Mfr#: 100013284
£314.94 ex VAT
£377.92 inc VAT
It is a spare lamp for P401W, P451W and P501X projectors.
  • Enhanced brightness
    This projector lamp is designed to enhance the brightness of your presentations and visuals, ensuring clear and vibrant images even in well-lit rooms.
  • Seamless compatibility
    Specially crafted for compatibility with PC, this projector lamp integrates smoothly with your existing setup, offering a hassle-free upgrade or replacement solution.
NEC NP23LP - projector lamp
Projector lamp
NEC NP-P401W, NP-P451W, NP-P451X, NP-P501X, P451W, P501X
Projector lamp
Type: Projector lamp
Brand: NEC
