Enhanced brightness
This projector lamp is designed to enhance the brightness of your presentations and visuals, ensuring clear and vibrant images even in well-lit rooms. -
Seamless compatibility
Specially crafted for compatibility with PC, this projector lamp integrates smoothly with your existing setup, offering a hassle-free upgrade or replacement solution.
- NEC NP23LP - projector lamp
- Product Type
- Projector lamp
- Designed For
- NEC NP-P401W, NP-P451W, NP-P451X, NP-P501X, P451W, P501X
- Product Type
- Projector lamp
- Designed For
