Extended lamp life
Enjoy a significant extension in your viewing pleasure with up to 4000 hours of lamp life in Economic Mode, ensuring long-lasting performance and reducing the need for frequent lamp replacements. -
Seamless compatibility
Designed specifically for PC use, this projector lamp integrates smoothly with your existing setup, offering a hassle-free upgrade or replacement solution.
- NEC NP29LP - projector lamp
- Product Type
- Projector lamp
- Bulb life cycle
- 4000 hour(s) (economic mode)
- 6 months warranty
- Designed For
- NEC M362W, M362WG
- Product Type
- Projector lamp
Lamp
- Life Cycle
- Limited warranty - 6 months / 1000 hours
- Designed For
- NEC M362W, M362WG
