The NEC P502HL is the smallest 5000 lumen installation projector with a laser/phosphor light source that makes it ideal for higher education classrooms, corporate boardrooms and government training rooms. With more consistent brightness, improved color fidelity, and tilt-free or portrait modes these projectors will deliver in verticals such as retail, simulation, and theme park installations. Furthermore, the laser module delivers long hours of virtually maintenance-free operations, reducing your total cost of ownership.
- NEC P502HL - DLP projector - 3D - LAN
- DLP projector - 1080p
- 3D Capable
- Yes (3D glasses sold separately)
- Built-in Devices
- Speaker
- Brightness
- 5000 ANSI lumens
- Contrast Ratio
- 150000:1
- Resolution
- Full HD (1920 x 1080)
- Native Aspect Ratio
- 16:9
- Lens Shift Direction
- Horizontal, vertical
- Bulb type
- Laser/phosphor
- Bulb life cycle
- Up to 20000 hour(s)
- Video Input
- Composite video (SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60, NTSC 3.58), LAN
- Speakers
- Speaker(s) - integrated
- Power
- AC 100/240 V (50/60 Hz)
- 442 Watt
- 46.9 cm x 36.5 cm x 13.7 cm
- 8.8 kg
- 3-year warranty
- 3D Capable
- Built-in Devices
- Speaker
Projector
- Brightness
- 5000 ANSI lumens
- Contrast Ratio
- 150000:1
- Image Size
- 76.2 cm - 762 cm
- Projection Distance
- 0.8 m - 14.2 m
- Throw Ratio
- 1.24 - 2.1:1
- Resolution
- Full HD - Full HD (1920 x 1080)
- 16:9
- Max Sync Rate (V x H)
- 120 Hz x 100 kHz
- Bulb type
- Laser/phosphor
- Bulb life cycle
- Controls & Adjustments
- Keystone correction, lens shift dial (horizontal), lens shift dial (vertical)
- Wall colour correction, DICOM Simulation Mode, Direct Power Off, Auto Power Off, built-in test pattern, auto power on, USB Viewer, Geometric Correction, Carbon Savings Meter, Virtual Remote, sleep timer
Lens
- Focus Type
- Manual
- Lens Aperture
- F/2.0-2.5
- Zoom Type
- Manual
- Zoom Factor
- 1.7x
- Keystone Correction Direction
- Vertical Keystone Correction
- -30 / +30
- Horizontal Keystone Correction
- -25 / +25
- Vertical Lens Shift
- 62%
- Horizontal Lens Shift
- 25% / 25%
Video Input
- TV System
- SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60, NTSC 3.58
- Analogue video Signal
- Composite video
- Video Interfaces
- VGA, HDMI, composite video
- LAN and Wireless Image Transferring Protocols
- Wired LAN
Speakers
- Integrated
- Sound Output Mode
- Mono
- Output Power / Channel
- 20 Watt
- Speakers
- 1 x mixed channel
- 1 x VGA input - 15 pin HD D-Sub (HD-15) , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 2 x HDMI input - 19 pin HDMI Type A , 1 x composite video input - RCA , 1 x audio line-in - RCA x 2 , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x serial RS-232 - 9 pin D-Sub (DB-9) , 1 x network - RJ-45 , 1 x HDBaseT - RJ-45 , 1 x USB - 4 pin USB Type A , 1 x 3D Sync out - 3 PIN mini-DIN
- Included Accessories
- Wireless remote control
- Cables Included
- 1 x VGA cable - 1.8 m
- Security Features
- Security lock slot (cable lock sold separately), security label, keypad lock
- Plug and Play, RoHS, ERP
- Power Source
- AC
- Voltage Required
- 442 Watt
- Power Consumption Stand by
- 0.3 Watt
- 46.9 cm
- 36.5 cm
- 13.7 cm
- 8.8 kg
- EMEA warranty - 3 years
- Sound Emission
- 39 dB
- Sound Emission (Economic Mode)
- 33 dB
