NEC P451W WXGA 3LCD 4500 Lumens Projector
Quicklinx: 96QTWS00 Mfr#: 60003449
Thanks to the compact design, large optical zoom of 1.7x, and vertical as well as horizontal keystone correction you are very flexible in placing the projector in the room without compromising too much on overall design and room integration. In addition to remote control and monitoring over wired also content transmission including audio is supported.
With 4500 ANSI lumens brightness this very bright and compact projector is recommended for screen sizes of up to 140" which makes it perfect for mid to large meeting rooms as well as classrooms in higher education.
NEC P451W - LCD projector
LCD projector
Brightness
4500 ANSI lumens
Contrast Ratio
4000:1
Resolution
WXGA (1280 x 800)
Native Aspect Ratio
16:10
Lens Shift Direction
Vertical
Bulb type
UHP 270 Watt
Bulb life cycle
Up to 4000 hour(s) - normal mode , Up to 6000 hour(s) - economic mode
Video Input
RGB, S-Video, composite video (SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60, NTSC 3.58)
Speakers
Speaker(s) - integrated
AC 120/230 V (50 - 60 Hz)
357 Watt
39.8 cm x 11.5 cm x 28.2 cm
4.1 kg
3-year warranty
LCD projector
Projector
Brightness
4500 ANSI lumens
Contrast Ratio
4000:1
Image Size
64 cm - 762 cm
Projection Distance
0.6 m - 13.8 m
Throw Ratio
1.3 - 2.2:1
Resolution
WXGA - WXGA (1280 x 800) (native) / 1920 x 1200 (resized)
Native Aspect Ratio
16:10
Max Sync Rate (V x H)
120 Hz x 100 kHz
Bulb type
UHP 270 Watt
Bulb life cycle
Controls & Adjustments
Keystone correction
Eco-Mode technology, wall colour correction, USB host function, Geometric Adjustment, Intelligent Power Management, DICOM Simulation Mode, Direct Power Off, Auto Power Off, built-in test pattern
Lens
Focus Type
Manual
Lens Aperture
F/1.7-2.0
Zoom Factor
1.7x
Keystone Correction Direction
Horizontal, vertical
Vertical Keystone Correction
-30 / +30
Horizontal Keystone Correction
-30 / +30
Vertical
Video Input
TV System
Analogue video Signal
Video Interfaces
VGA, HDMI, composite video, S-Video
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
16 Watt
1 x VGA input - 15 pin HD D-Sub (HD-15) , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 2 x HDMI - 19 pin HDMI Type A , 1 x composite video input - RCA , 1 x S-video input - 4 pin mini-DIN , 1 x audio line-in - mini-phone mono 3.5 mm , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-in - RCA x 2 , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x serial RS-232 input - 9 pin D-Sub (DB-9) , 1 x USB - 4 pin USB Type B , 2 x USB 2.0 - 4 pin USB Type A
Lens cover, wireless remote control
1 x VGA cable - VGA to VGA - 1.8 m
Security Features
Security lock slot (cable lock sold separately), password protection, security label, keypad lock
TUV GS, RoHS, ERP
357 Watt
Power Consumption Stand by
10 Watt
Software Included
Drivers & Utilities
39.8 cm
11.5 cm
28.2 cm
4.1 kg
EMEA warranty - 3 years , Limited warranty - lamp - 6 months / 1000 hours
Sound Emission
37 dB
30 dB
