NEC NP2200 XGA Projector
Quicklinx: 6L3BWS00 Mfr#: 60002811
Achieve outstanding performance and energy efficiency during presentations with the NEC NP2200, an eco-friendly installation projector ideal for higher education and corporate environments. This affordable model delivers remarkably bright images and features easy-to-use networking technologies, high contrast and up to 3000 hours of lamp life (in ECO Mode). Compared to comparable projectors, it consumes less power, starts up and shuts down quicker, and features a carbon footprint meter, longer filter usage time and lamp life (in ECO Mode). Whether in the classroom or boardroom, the NP2200's multitude of advanced technologies allows you to connect with your audience using bright, colorful images and crisp text.
  • With XGA native resolution
    Up to 4200 lumens and patented NEC technologies, the NP2200 displays impressive image quality.
  • Comprehensive input panel
    Include a 5BNC input that supports RGB, component and composite signals to support the multitude of sources being attached to the projector.
  • Variable audio-out
    Enable remote control to be used to adjust volume of self-powered external speakers that are connected to the projector. In stand-by mode, the audio-out stays active, allowing the last input used to pass to the self-powered external speakers.
  • Easy control from remote
    Allow you to adjust lamp mode, aspect ratio, volume and image all with the touch of a button.
  • Extended lamp life with ECO Mode technology
    Increase lamp life up to 3000 hours, while lowering power consumption.
  • Power management
    Enable projector to automatically turn off when an incoming signal is not detected from any of the inputs.
  • Carbon savings meter
    Calculate the positive effects of operating the projector in ECO Mode, which is encouraged by an optional message at startup. A green ECO Mode button on the remote control makes the switch easy.
  • Quick start (5 seconds)
    Let you begin presenting in seconds while quick shutdown (immediate power off with no cooling required after shutdown) ensures efficient energy usage.
  • Sleep timer
    It can be set to automatically turn off the projector at set countdown times.
  • Filter life
    Increase by three times compared to previous generation models.
  • AccuBlend
    Ensure detailed images when non-native resolution sources are connected to the projector.
  • AutoSense
    Automatically syncs with any computer signal and features one-touch image optimization.
  • Remote diagnostics
    Enable the user to monitor and make adjustments to the projector remotely.
  • Built-in HTTP page
    It's for control and monitoring over a LAN network. Email notification of error messages or lamp end-of-life can be sent to remote locations.
NEC NP2200 - LCD projector - standard lens
LCD projector
Built-in Devices
Stereo speakers
Ethernet
Brightness
4200 lumens
Contrast Ratio
600:1
Resolution
XGA (1024 x 768)
Lens
Standard lens
Lens Shift Direction
Horizontal, vertical
Bulb type
300 Watt
Bulb life cycle
Up to 2000 hour(s) - normal mode , Up to 3000 hour(s) - economic mode
Video Input
RGB, S-Video, composite video, component video (NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60)
Digital Video Standard
Digital Visual Interface (DVI)
Video Modes
480p, 720p, 1080i, 480i, 576i, 576p
Video Output
RGB
Speakers
Speaker(s) - integrated
Microsoft Certification
Compatible with Windows 7
393 Watt
39.9 cm x 35.8 cm x 15 cm
7.4 kg
3-year warranty
LCD projector
Built-in Devices
Stereo speakers
Ethernet
Ethernet
Projector
Brightness
4200 lumens
Contrast Ratio
600:1
Image Size
63.5 cm - 1270 cm
Projection Distance
0.74 m - 20.9 m
Throw Ratio
1.5 - 2.0:1
Resolution
XGA - XGA (1024 x 768) (native) / 1600 x 1200 (resized)
Max Sync Rate (V x H)
120 Hz x 100 kHz
Bulb type
300 Watt
Bulb life cycle
Controls & Adjustments
Keystone correction, zoom
Eco-Mode technology, AutoSense technology, Advanced AccuBlend technology, 3D Reform technology, Micro Lens Array (MLA) Technology, High-bandwidth Digital Content Protection System (HDCP), wall colour correction, Hollywood Quality Video (HQV)
Lens
Standard lens
Focus Type
Manual
Lens Aperture
F/1.7-2.2
Zoom Factor
1.33x
Keystone Correction Direction
Vertical Keystone Correction
-30 / +30
Lens Shift Type
Manual
Vertical Lens Shift
50%
Horizontal Lens Shift
10% / 10%
Video Input
TV System
Analogue video Signal
Video Interfaces
VGA, component video, composite video, S-Video, DVI, RGB
Video Modes
Video Output
Analogue Video Signal
RGB
Speakers
Integrated
Sound Output Mode
Stereo
Output Power / Channel
5 Watt
Speakers
2 x right / left channel
Input Device
External
Movement Detection Technology
Infrared
1 x VGA input - 15 pin HD D-Sub (HD-15) , 1 x RGB input - BNC x 5 , 1 x DVI-D input - 24+1 pin digital DVI , 1 x composite video input - RCA , 1 x S-video input - 4 pin mini-DIN , 1 x component video input - RCA x 3 , 2 x audio line-in - RCA x 2 , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x serial RS-232 - 9 pin D-Sub (DB-9) , 1 x USB - 4 pin USB Type B , 1 x network - RJ-45 , 3 x audio line-in - mini-phone stereo 3.5 mm , 1 x stacking , 1 x remote control - mini-phone 3.5 mm , 1 x VGA output - 15 pin HD D-Sub (HD-15)
Lens cover, wireless remote control
1 x remote control cable , 1 x VGA cable
Security Features
Security lock slot (cable lock sold separately), password protection, control panel lock, My Screen lock
FCC Class B certified, cUL, NOM, UL 1950, CSA 22.2 No. 950
393 Watt
Power Consumption Operational (Standby)
0.4 Watt
39.9 cm
35.8 cm
15 cm
7.4 kg
Limited warranty - parts and labour - 3 years , Limited warranty - lamp - 1 year
5 °C
20 - 80%
Sound Emission
33 dB
30 dB
