Versatile zoom capability
Equipped with a manual zoom feature and a lens aperture of f/2.2-2.64, this lens offers flexibility in adjusting the image size without changing the projector's position. Whether it's a small room or a large hall, the NEC NP14ZL lens adapts to different projection distances, ensuring clear and precise images. -
Extended projection range
With a projection distance ranging from 3.7 m to 50.9 m, this lens is capable of delivering large, detailed images in various settings. From intimate meetings to large-scale presentations, the NEC NP14ZL lens ensures your content is displayed with clarity and precision. -
Optimized for NEC projectors
Designed specifically for projector use, this lens integrates seamlessly with NEC models, enhancing their performance. The focus and zoom adjustments are manual, allowing for fine-tuning that matches the specific requirements of your presentation or viewing environment.
- NEC NP14ZL - zoom lens - 48.5 mm - 77.6 mm
- Lens System
- Zoom lens
- Intended For
- Projector
- Lens Aperture
- F/2.2-2.64
- Focal Length
- 48.5 mm - 77.6 mm
- Optical Zoom
- 1.6 x
- Focus Adjustment
- Manual
- Special Functions
- Zoom
- 1 kg
- Designed For
- NEC NP-PA1004, NP-PA1004UL-B-41, NP-PA500, NP-PA500U-13, NP-PA500X-13, NP-PA550, NP-PA600, NP-PA653, NP-PA803, NP-PA804, NP-PA804UL-B-41, NP-PA804UL-W-41, NP-PA853, NP-PA903, PA1004, PA500, PA550, PA600, PA653, PA703, PA803, PA804, PA853, PA903; PA Series NP-PA1004UL-W-41
- 1 kg
Lens System
- Zoom lens
- Special Functions
- Zoom
- Intended For
- Projector
- Focal Length
- 48.5 mm - 77.6 mm
- Lens Aperture
- F/2.2-2.64
- Optical Zoom
- 1.6 x
- Focus Adjustment
- Manual
- Zoom Adjustment
- Manual
- Projection Distance
- 3.7 m (min) - 50.9 m (max)
- Throw Ratio
- 2.97-4.79:1
- Designed For
- NEC NP-PA1004UL-B, NP-PA1004UL-B-41, NP-PA1004UL-W, NP-PA500U, NP-PA500U-13ZL, NP-PA500X, NP-PA500X-13ZL, NP-PA550W, NP-PA600X, NP-PA653U, NP-PA803U, NP-PA804UL-B, NP-PA804UL-B-41, NP-PA804UL-W, NP-PA804UL-W-41, NP-PA853W, NP-PA903X, PA1004UL, PA500U, PA500X, PA550W, PA600X, PA653U, PA703W, PA803U, PA804UL, PA853W, PA903X , NEC PA Series NP-PA1004UL-W-41
