NEC MultiSync X461S - 46" Class ( 46" viewable ) LCD flat panel
Quicklinx: 806ZWS00 Mfr#: 60003056
  • 1080p
Operating digital signage has never been easier than with the 46" NEC X461S. This super-slim Full HD LCD display offers LED backlighting technology to deliver high-quality imagery at a lower power consumption than its peers. The industry's first standardized input, the Open Pluggable Specification (OPS) slot, increases flexibility for users in any digital signage application, including video walls where the X461S can be implemented into configurations up to 10 x 10.
NEC MultiSync X461S 46" LED-backlit LCD display - Full HD - for digital signage
LED-backlit LCD flat panel display
Diagonal Class
46"
Commercial Use
Yes - digital signage
Image Colour Disclaimer
The displayed product image may be a different colour
Resolution
1920 x 1080
Display Format
1080p
Video Interface
Composite, HDMI
HDMI Ports Qty
1 ports
PC Interface
DVI, VGA (HD-15), DisplayPort
HDCP Compatible
S-PVA
LCD Backlight Technology
Edge-lit LED
Image Aspect Ratio
16:9
TV Tuner
No tuner
Sound Output Mode
Stereo
Speaker System
1 speaker
Remote control
Voltage
135 Watt
106 cm x 4.3 cm x 61.8 cm
20 kg
3-year warranty
135 Watt
Diagonal Class
46"
Commercial Use
TV Tuner
No tuner
TV Tuner Presence
No
Sensors
Ambient light sensor (ALS), temperature sensor
Video Interface
Composite, HDMI
HDMI Ports Qty
1 ports
PC Interface
HDCP Compatible
Modes
Portrait mode, landscape mode
Dimensions
Without stand
106 cm
4.3 cm
61.8 cm
20 kg
Display
LCD Display Technology
S-PVA
Resolution
1920 x 1080
Display Format
1080p
Image Aspect Ratio
16:9
Edge-lit LED
Colour Depth
16.7 million colours
Image Contrast Ratio
3000:1
Brightness
600 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Pixel Pitch
0.53mm
Max V-Sync Rate
85 Hz
Max H-Sync Rate
91.1 kHz
AmbiBright, TileMatrix (10 x 10), Rapid Response technology, TileComp, CableComp+, Aspect ratio control (ARC)
Stands & Mounts
Flat Panel Mount Interface
300 x 300 mm
Video Features
Supported Computer Resolutions
1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA), 832 x 624, 1280 x 768 (WXGA), 1280 x 1024 (SXGA), 1600 x 1200 (UXGA), 720 x 400, 1360 x 768, 1920 x 1080
Remote Control
Remote control
Audio System
Sound Output Mode
Stereo
Speaker System
1 speaker
Output Power / Total
10 Watt
External Speakers Amplifier Power (Total)
30 Watt
Speakers
1 x speaker - 10 Watt
Connector Type
DisplayPort input , HDMI input , DVI-D input , DVI-D output , VGA input , Composite video input , LAN , Serial input , Serial output , Audio input , Audio output , 2 x speakers output
Expansion Slots
1 x Expansion Slot
Plug and Play, DDC-2B, EN 61000-3-2, VESA DPMS, EN 61000-3-3, DDC/CI, EN 60950-1, WEEE
Power adapter
Input Voltage
On/off timer
Limited warranty - parts and labour - 3 years
Dimensions & Weight Details
Panel with stand - 106 cm x 33 cm x 66.5 cm x 21 kg , Panel without stand - 106 cm x 4.3 cm x 61.8 cm x 20 kg
Width (Shipping)
123 cm
Depth (Shipping)
22.5 cm
Height (Shipping)
79.2 cm
Weight (Shipping)
25.2 kg
5 °C
20 - 80%
