Entry to the world of professional LCD public displays! It offers reliability and variability that is expected by demanding customers.
- NEC MultiSync V321 32" LCD flat panel display - HD - for digital signage
- Product Type
- LCD flat panel display
- Diagonal Class
- 32"
- Commercial Use
- Yes - digital signage
- Resolution
- 1366 x 768
- Display Format
- 720p
- Input Video Formats
- 480p, 720p, 1080i, 1080p, 480i, 576i, 576p, 1080/60i, 720/60p, 1080/50i, 720/50p, 1080/50p, 1080/60p
- Video Interface
- Component, composite, HDMI, S-Video
- PC Interface
- DVI, VGA (HD-15), HDMI
- HDCP Compatible
- Technology
- S-PVA
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Picture Enhancements
- XtraView+
- Sound Output Mode
- Stereo
- Speaker System
- Speakers not included
- Included Accessories
- Remote control
- Microsoft Certification
- Works with Windows Vista
- Voltage
- AC 120/230 V (50/60 Hz)
- 120 Watt
- 78.9 cm x 13.3 cm x 47.6 cm
- 13.1 kg
- Product Type
- 120 Watt
- Diagonal Class
- 32"
- Commercial Use
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Sensors
- Temperature sensor
- Video Interface
- PC Interface
- HDCP Compatible
- XtraView+
- 78.9 cm
- 13.3 cm
- 47.6 cm
- 13.1 kg
Display
- LCD Display Technology
- S-PVA
- Resolution
- 1366 x 768
- Display Format
- 720p
- 16:9
- Colour Depth
- 16.7 million colours
- Image Contrast Ratio
- 3000:1
- Brightness
- 450 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Pixel Pitch
- 0.511mm
- Response Time
- 8 ms
- Max V-Sync Rate
- 85 Hz
- Max H-Sync Rate
- 91.1 kHz
- No Touch Auto Adjust, front panel lockout, Rapid Response technology, TileComp, TileMatrix
Stands & Mounts
- Flat Panel Mount Interface
- 200 x 200 mm
Video Features
- 16:9 Mode
- Analogue Video Input Signals
- NTSC, PAL, SECAM
- Supported Computer Resolutions
- 1440 x 1050, 1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA), 832 x 624, 1280 x 1024 (SXGA), 1600 x 1200 (UXGA), 720 x 400, 1920 x 1080
Remote Control
- Remote control
Audio System
- Sound Output Mode
- Stereo
- Speaker System
- External Speakers Amplifier Power (Total)
- 14 Watt
- Connector Type
- Composite video output , Composite video input , 2 x audio input , Audio input , Serial input , Serial output , LAN , VGA input , VGA output , DVI-D input , HDMI input , S-Video input , Audio output , 2 x speakers output , Component video input
- Cables Included
- VGA cable
- Software and devices that carry the Works with Windows Vista logo have been tested for baseline compatibility with PC's running.
- CCC
- Power Device
- Power supply - internal
- Input Voltage
- On / Off Switch
- No
- On/off timer
