NEC MultiSync PA272W 27" AH-IPS LED-Backlit LCD Monitor
Quicklinx: 95T4WS00 Mfr#: 60003489
Color accuracy that you can trust. The 27" MultiSync PA272W is the benchmark desktop display for color accurate applications. The GB-R LED backlight provides 99.3% coverage of the Adobe RGB color space while consuming up to 37% less power than comparable CCFL backlights. Utilizing a high performance AH-IPS LCD panel, the MultiSync PA272W will reliably deliver high quality, accurate images simply and beautifully.
  • 3D LUT
    Internal 14-bit programmable 3D lookup tables (LUTs) allow the display of 1.07 billion colors out of a palette of 4.3 trillion (with 10-bit DisplayPort input) for accurate color, smooth images and hardware calibration.
  • Ambix4
    Allows up to four inputs (DisplayPort, VGA and two DVI-D) to be connected to a single monitor and for each of the four signals to be displayed with the press of a button.
  • XtraView+
    Delivers wide viewing angles of up to 178º horizontally and vertically (up to 89º up, down, left and right) with less color shift and without any glare, reflection or distortion.
  • Rapid Response
    Delivers virtually uninterrupted, undistorted viewing of high-speed, full-motion video.
  • AmbiBright
    Automatically adjusts the backlight depending on the brightness of ambient lighting conditions. It also tells the monitor to enter power saving mode whenever the ambient lighting falls below a predetermined value (like when lights are shut off at the end of the day), which can significantly reduce energy consumption.
  • CableComp
    Equalizes the video signal to eliminate color halos on long cable runs.
  • Digital uniformity compensation
    Reduces screen uniformity errors and compensates for differences in color/grayscale and luminance using signal processing circuitry.
NEC MultiSync PA272W - LED monitor - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class C
Energy Consumption per Year
73 kWh
Power Consumption (On mode)
50 W
USB 2.0 hub
Panel Type
AH-IPS
Aspect Ratio
16:9
Native Resolution
2560 x 1440 at 60 Hz
Pixel Pitch
0.233 mm
Brightness
340 cd/m²
Contrast Ratio
1000:1
Response Time
6 ms (grey-to-grey), 16 ms (8 ms black-to-white)
Colour Support
1.07 billion colours
Colour Gamut
108.6% Adobe RGB, 99.3% Adobe RGB
Input Connectors
HDMI, DVI-D, DisplayPort, Mini DisplayPort
Display Position Adjustments
Voltage
64.04 cm x 23.55 cm x 39.62 cm
12.9 kg
FCC Class B certified, MPR II, CSA, UL, TUV GS, C-Tick, GOST, cUL, DDC-2B, MPR III, PCBC, PCT, VESA EDID, CCC, TUV Ergo, PSB, DDC/CI, RoHS, ISO 9241-307, ERP
3-year warranty
Display Type
Energy Class
Class C
73 kWh
Diagonal Size
27"
Built-in Devices
USB 2.0 hub
Panel Type
AH-IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.233 mm
Brightness
340 cd/m²
Contrast Ratio
1000:1
Colour Support
Colour Gamut
Response Time
Vertical Refresh Rate
50 - 85 Hz
Horizontal Refresh Rate
31.5 - 96.5 kHz
Horizontal Viewing Angle
+89 / -89
Vertical Viewing Angle
+89 / -89
Backlight Technology
GB-r LED backlight
Picture in picture, CableComp, AutoBright, picture by picture, TileMatrix, ColorComp, Eco-Mode, Overdrive technology, TileComp, RapidMotion, Auto Contrast, automatic black level adjustment, Carbon Footprint Meter, Carbon Savings Meter, TORO Design, 14-bit lookup table, Direct Brightness and Contrast, 3D LUT
64.04 cm x 23.55 cm x 39.62 cm - with stand
12.9 kg
HDMI , Mini DisplayPort , DisplayPort , DVI-D (dual link) , 2 x USB 2.0 upstream (Type B) , 3 x USB 2.0 downstream (Type A)
Mechanical
Tilt Angle
-5/+30
Swivel Angle
90
Rotation Angle
90
Height Adjustment
150 mm
VESA Mounting Interface
100 x 100 mm, 200 x 100 mm
Security lock slot (cable lock sold separately), integrated cable management
1 x Mini DisplayPort cable , 1 x DVI cable
Power Supply
Internal
Input Voltage
50 W
Power Consumption (Typical)
73 Watt
Power Consumption Stand by
1.4 Watt
Power Consumption Sleep
0.5 Watt
Dimensions & Weight Details
With stand - width: 64.04 cm - depth: 23.55 cm - height: 29.62 cm - weight: 12.9 kg , Without stand - width: 64.04 cm - depth: 8.5 cm - height: 37.86 cm - weight: 8.9 kg
Limited warranty - 3 years , Limited warranty - backlight - 3 years
5 °C
35 °C
20 - 80%
