NEC MultiSync PA231W - LCD monitor - Full HD (1080p) - 23"
Quicklinx: 7T60WS00 Mfr#: 60002927
NEC MultiSync PA Series monitors feature a custom-designed color processor called the SpectraView engine. This sophisticated processor, combined with internal luminance, temperature and time monitoring of the monitor, and individual characterization and calibration of each unit during production, results in an unparalleled level of color control, accuracy and stability.
The wide color gamut and high-contrast LCD panel used on the monitor, coupled with the SpectraView engine, provide the utmost in versatility; from the ability to accurately emulate colorspaces such as AdobeRGB and sRGB, to performing printer output emulations using ICC profiles and internal 3D look up tables.
LCD monitor - 23"
USB 2.0 hub
Panel Type
IPS
Native Resolution
Pixel Pitch
0.265 mm
Brightness
270 cd/m²
Contrast Ratio
1000:1
Response Time
8 ms (grey-to-grey), 14 ms (typical)
Colour Support
16.7 million colours
Input Connectors
2xDVI-D, VGA, DisplayPort
Display Position Adjustments
Height, swivel, tilt
Voltage
White
54.4 cm x 22.8 cm x 33.8 cm
10.2 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified EPEAT Silver
FCC Class B certified, CSA, UL, TUV GS, C-Tick, VCCI Class B ITE, GOST, cUL, DDC-2B, MPR III, PCBC, PCT, VESA DPMS, CCC, TUV Ergo, DOC, PSB, DDC/CI, RoHS, UL 60950-1, ISO 9241-307
3-year warranty
Display Type
LCD monitor / TFT active matrix
Diagonal Size
23"
Built-in Devices
USB 2.0 hub
Panel Type
IPS
Native Resolution
Pixel Pitch
0.265 mm
Brightness
270 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
Vertical Refresh Rate
85 Hz
Horizontal Refresh Rate
118.4 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Controls & Adjustments
Brightness, contrast, sharpness, colour balance, colour temperature, black level
Picture in picture, OmniColor, CableComp, Rapid Response, AutoBright, Advanced No Touch Auto Adjust, picture by picture, cable management cover, sRGB colour management, TileMatrix, HDCP, NaViSet, ColorComp, AmbiBright, Eco-Mode, Overdrive technology, Digital Uniformity Equalizer (DUE), 75% colour gamut, TileComp, RapidMotion
White
54.4 cm x 22.8 cm x 33.8 cm - with stand
10.2 kg
3 x USB 2.0 downstream , 2 x USB 2.0 upstream (Type B) , 2 x DVI-D , VGA , DisplayPort
Mechanical
Tilt Angle
35
Rotation Angle
90
Height Adjustment
150 mm
VESA Mounting Interface
100 x 100 mm, 200 x 100 mm
1 x VGA cable - 2 m , 1 x DisplayPort cable - 2 m , 1 x DVI cable - 2 m
Power Supply
Internal
Input Voltage
Power Consumption (Typical)
46 Watt
Power Consumption Stand by / Sleep
1 Watt
Included Software
Drivers & Utilities, NaViSet
Sustainability Information
EPEAT Compliant
EPEAT Silver
ENERGY STAR Certified
Limited warranty - 3 years , Limited warranty - backlight - 3 years
5 °C
35 °C
30 - 80%
