The slimmer, lighter MultiSync P553 is packed with additional features that make it the ideal professional choice for any 24/7 Retail, Transportation, Corporate or Control Room applications that demand trusted performance, flexibility and lower costs of operation.
New connectivity and sensors allow additional creativity in the content displayed and how it is controlled. The unique built-in NFC sensor in combination with NEC's new Android app reduces installation and maintenance times, especially useful on larger installations. The Human Sensor is aware of proximity based viewer presence and can change brightness, volume, inputs or power the display up or down resulting in added engagement and considerable energy savings over time.
- NEC MultiSync P553 PG P Series - 55" LED-backlit LCD display - for digital signage
- Product Type
- LED-backlit LCD flat panel display
- Diagonal Class
- 55"
- Commercial Use
- Yes - digital signage
- Resolution
- 1920 x 1080
- Video Interface
- HDMI
- HDMI Ports Qty
- 1 ports
- PC Interface
- DVI, VGA (HD-15), DisplayPort
- HDCP Compatible
- Technology
- S-PVA
- LCD Backlight Technology
- Edge-lit LED
- TV Tuner
- No tuner
- Speaker System
- 2 speakers
- Included Accessories
- Remote control
- Voltage
- AC 120/230 V (50/60 Hz)
- Energy Class
- Class B
- 315 Watt
- Power Consumption (On mode)
- 140 W
- Power Consumption Stand by
- 1 Watt
- Energy Consumption per Year
- 204 kWh
- Dimensions (WxDxH) - without stand
- 125.02 cm x 7.03 cm x 72.1 cm
- 35.1 kg
- Environmental Standards
- ENERGY STAR Qualified
- 3-year warranty
- Product Type
- Energy Class
- Class B
- 315 Watt
- 140 W
- 204 kWh
- Diagonal Class
- 55"
- Commercial Use
- Series
- P Series
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Sensors
- Ambient light sensor (ALS), temperature sensor, NFC sensor
- Video Interface
- HDMI
- HDMI Ports Qty
- 1 ports
- PC Interface
- HDCP Compatible
- Modes
- Eco mode
- Dimensions
- Without stand
- 125.02 cm
- 7.03 cm
- 72.1 cm
- 35.1 kg
Display
- LCD Display Technology
- S-PVA
- Resolution
- 1920 x 1080
- Edge-lit LED
- Coating
- Anti-reflection
- Image Contrast Ratio
- 4000:1
- Brightness
- 700 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Response Time
- 8 ms
- NaViSet, Open Pluggable Specification slot
Stands & Mounts
- Stand
- Optional
- Flat Panel Mount Interface
- 300 x 300 mm
Video Features
- Supported Computer Resolutions
- 1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA), 1280 x 768 (WXGA), 1280 x 1024 (SXGA), 1600 x 1200 (UXGA), 1360 x 768, 1920 x 1080, 3840 x 2160, 4096 x 2160
Remote Control
- Remote control
Audio System
- Speaker System
- 2 speakers
- Output Power / Total
- 20 Watt
- External Speakers Amplifier Power (Total)
- 30 Watt
- Speakers
- 2 x main channel speaker - 10 Watt
- Connector Type
- DVI-D input , HDMI input , DisplayPort input , DisplayPort output , VGA input , Remote control input , Serial input , 2 x audio input , 2 x LAN , USB , Audio output , 2 x speakers output
- Cables Included
- DVI cable
- FCC Class B certified, CSA, UL, TUV GS, VCCI, C-Tick, cUL, VESA DPMS, VESA FDMI, PSB, RoHS
Sustainability Information
- ENERGY STAR Certified
- ENERGY STAR Version
- 6.0
- Power Device
- Power supply
- Input Voltage
- 1 Watt
- Limited warranty - 3 years , Limited warranty - backlight - 3 years
- 0 °C
- 40 °C
- 20 - 80%
