The NEC MultiSync P242W delivers outstanding image quality with class-leading ergonomics for demanding professional applications. 15 cm height adjust, DisplayPort connector, digital uniformity control, integrated USB hub and Picture-in-Picture give advanced users all the flexibility and image quality to ensure highest personal productivity. This outstanding display cabinet has won the prestigious iF Design Award.
Ergonomic office
Full height adjustability (150 mm), swivel, tilt and pivot functionality ensures perfect individual ergonomic set-up. -
Extraordinary features
Such as digital uniformity control, picture-in-picture, USB hub, 3D LUT color space emulation, backlight ageing correction, DisplayPort. -
Future-proof connectivity
As well as easier support of high resolution and HDMI signals, 10-bit color input signals is assured with the DisplayPort connector. -
Improved productivity and reduced desk clutter
Through easy multi-platform support and input follow USB hub. Picture-by-picture allows two different platforms to be simultaneously viewed. A single mouse and keyboard can be switched to the active operating system. -
Sustainable office
It features low power consumption with LED backlight and ambient light sensor.
- NEC MultiSync P242W - LED monitor - 24.1"
- LED-backlit LCD monitor - 24.1"
- Energy Class
- Class A
- Energy Consumption per Year
- 32 kWh
- Power Consumption (On mode)
- 22 W
- USB 2.0 hub
- Panel Type
- IPS
- Native Resolution
- 1920 x 1200 at 60 Hz
- Pixel Pitch
- 0.27 mm
- Brightness
- 350 cd/m²
- Contrast Ratio
- 1000:1
- Response Time
- 8 ms (grey-to-grey), 16 ms (tr - tf)
- Colour Support
- 16.8 million colours
- Colour Gamut
- 75% Adobe RGB
- Input Connectors
- HDMI, DVI-D, VGA, DisplayPort
- Height, pivot (rotation), swivel, tilt
- Voltage
- AC 120/230 V
- Black
- 55.68 cm x 22.76 cm x 37.8 cm
- 10.1 kg
- Microsoft Certification
- Compatible with Windows 7
- FCC Class B certified, MPR II, CSA, UL, TUV GS, C-Tick, GOST, cUL, DDC-2B, MPR III, PCBC, PCT, VESA EDID, CCC, TUV Ergo, PSB, DDC/CI, RoHS, ISO 9241-307, WEEE, ERP
- 3-year warranty
- Display Type
- Energy Class
- Class A
- 32 kWh
- Diagonal Size
- 24.1"
- Built-in Devices
- USB 2.0 hub
- Panel Type
- IPS
- Native Resolution
- Pixel Pitch
- 0.27 mm
- Brightness
- 350 cd/m²
- Contrast Ratio
- 1000:1
- Colour Support
- Colour Gamut
- 75% Adobe RGB
- Response Time
- Vertical Refresh Rate
- 50 - 85 Hz
- Horizontal Refresh Rate
- 31.5 - 118.4 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- WLED
- Controls & Adjustments
- Brightness, contrast, sharpness, colour temperature, black level
- Ambient light sensor, OmniColor, CableComp, Rapid Response, Advanced No Touch Auto Adjust, Intelligent Power Manager (IPM), sRGB colour management, TileMatrix, NaViSet, ColorComp, AmbiBright, Eco-Mode, Overdrive technology, DICOM calibrated, TileComp, RapidMotion, OSD lock, NaViSet Administrator, automatic black level adjustment, Carbon Footprint Meter, TORO Design
- Black
- 55.68 cm x 22.76 cm x 37.8 cm - with stand
- 10.1 kg
- DVI-D , HDMI , DisplayPort , VGA , 2 x USB 2.0 upstream , 3 x USB 2.0 downstream
Mechanical
- Tilt Angle
- -5/+35
- Swivel Angle
- 90
- Rotation Angle
- 90
- Height Adjustment
- 150 mm
- VESA Mounting Interface
- 100 x 100 mm, 200 x 100 mm
- Security lock slot (cable lock sold separately), cable organizer
- Cables Included
- 1 x DisplayPort cable , 1 x VGA cable , 1 x DVI cable - DVI-D to DVI-D
- Power Supply
- Internal
- Input Voltage
- AC 120/230 V
- 22 W
- Power Consumption Stand by
- 1 Watt
- Dimensions & Weight Details
- Without stand - width: 55.68 cm - depth: 8.5 cm - height: 36.24 cm - weight: 7.4 kg , With stand - width: 55.68 cm - depth: 22.76 cm - height: 37.8 cm - weight: 10.1 kg
- Limited warranty - 3 years , Limited warranty - backlight - 3 years
- 5 °C
- 35 °C
- 30 - 80%
