Brand
NEC Multisync P242W 24" 1920x1200 DVI HDMI DisplayPort LED Monitor
Quicklinx: 993GWS00 Mfr#: 60003418
The NEC MultiSync P242W delivers outstanding image quality with class-leading ergonomics for demanding professional applications. 15 cm height adjust, DisplayPort connector, digital uniformity control, integrated USB hub and Picture-in-Picture give advanced users all the flexibility and image quality to ensure highest personal productivity. This outstanding display cabinet has won the prestigious iF Design Award.
  • Ergonomic office
    Full height adjustability (150 mm), swivel, tilt and pivot functionality ensures perfect individual ergonomic set-up.
  • Extraordinary features
    Such as digital uniformity control, picture-in-picture, USB hub, 3D LUT color space emulation, backlight ageing correction, DisplayPort.
  • Future-proof connectivity
    As well as easier support of high resolution and HDMI signals, 10-bit color input signals is assured with the DisplayPort connector.
  • Improved productivity and reduced desk clutter
    Through easy multi-platform support and input follow USB hub. Picture-by-picture allows two different platforms to be simultaneously viewed. A single mouse and keyboard can be switched to the active operating system.
  • Sustainable office
    It features low power consumption with LED backlight and ambient light sensor.
NEC MultiSync P242W - LED monitor - 24.1"
LED-backlit LCD monitor - 24.1"
Energy Class
Class A
Energy Consumption per Year
32 kWh
Power Consumption (On mode)
22 W
USB 2.0 hub
Panel Type
IPS
Native Resolution
1920 x 1200 at 60 Hz
Pixel Pitch
0.27 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1
Response Time
8 ms (grey-to-grey), 16 ms (tr - tf)
Colour Support
16.8 million colours
Colour Gamut
75% Adobe RGB
Input Connectors
HDMI, DVI-D, VGA, DisplayPort
Display Position Adjustments
Voltage
AC 120/230 V
White
55.68 cm x 22.76 cm x 37.8 cm
10.1 kg
Microsoft Certification
Compatible with Windows 7
FCC Class B certified, MPR II, CSA, UL, TUV GS, C-Tick, GOST, cUL, DDC-2B, MPR III, PCBC, PCT, VESA EDID, CCC, TUV Ergo, PSB, DDC/CI, RoHS, ISO 9241-307, WEEE, ERP
3-year warranty
Display Type
Energy Class
Class A
32 kWh
Diagonal Size
24.1"
Built-in Devices
USB 2.0 hub
Panel Type
IPS
Native Resolution
Pixel Pitch
0.27 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1
Colour Support
Colour Gamut
75% Adobe RGB
Response Time
Vertical Refresh Rate
50 - 85 Hz
Horizontal Refresh Rate
31.5 - 118.4 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
WLED
Controls & Adjustments
Brightness, contrast, sharpness, colour temperature, black level
Ambient light sensor, OmniColor, CableComp, Rapid Response, Advanced No Touch Auto Adjust, Intelligent Power Manager (IPM), sRGB colour management, TileMatrix, NaViSet, ColorComp, AmbiBright, Eco-Mode, Overdrive technology, DICOM calibrated, TileComp, RapidMotion, OSD lock, NaViSet Administrator, automatic black level adjustment, Carbon Footprint Meter, TORO Design
White
55.68 cm x 22.76 cm x 37.8 cm - with stand
10.1 kg
DVI-D , HDMI , DisplayPort , VGA , 2 x USB 2.0 upstream , 3 x USB 2.0 downstream
Mechanical
Tilt Angle
-5/+35
Swivel Angle
90
Rotation Angle
90
Height Adjustment
150 mm
VESA Mounting Interface
100 x 100 mm, 200 x 100 mm
Security lock slot (cable lock sold separately), cable organizer
1 x DisplayPort cable , 1 x VGA cable , 1 x DVI cable - DVI-D to DVI-D
Power Supply
Internal
Input Voltage
AC 120/230 V
22 W
Power Consumption Stand by
1 Watt
Dimensions & Weight Details
Without stand - width: 55.68 cm - depth: 8.5 cm - height: 36.24 cm - weight: 7.4 kg , With stand - width: 55.68 cm - depth: 22.76 cm - height: 37.8 cm - weight: 10.1 kg
Limited warranty - 3 years , Limited warranty - backlight - 3 years
5 °C
35 °C
30 - 80%
