Professional IPS performance desktop display delivers uncompromising image quality as well as minimizing life-cycle environmental impact. Uniting outstanding color reproduction, class-leading ergonomics, a built-in carbon savings meter, ambient light sensor and IPS performance makes it ideal for creative professionals.
The ideal display is design for all creative professionals, designers, photographers, CAD-CAM, video-editing, finance, precision engineering and industrial applications and anyone who cares about their visual work. This excellent display design has won the prestigious iF design award.
Ergonomic office
Full height adjustability, swivel, tilt and pivot functionality ensures perfect individual ergonomic set-up. -
Future-proof connectivity
As well as easier support of high resolution, IPS color signal is assured with DisplayPort and HDMI connectors. -
Improved productivity and reduced desk clutter
Through easy multi-platform support and input USB hub, picture-by-picture allows two different platforms to be simultaneously viewed. A single mouse and keyboard can be switched to the active operating system. -
Instant real-time visualization
With the 3D LUT color emulation and the picture-in-picture function you can simulate accurately different lighting conditions with varying paper colors. -
Responsible approach to environmental impact
It is maintained, without any performance compromise: ambient light sensor, carbon footprint meter/carbon savings meter and efficient cabinet packing design. -
Sustainable office
It has low power consumption with LED backlight and ambient light sensor.
- NEC MultiSync P232W - LED monitor - Full HD (1080p) - 23"
- LED-backlit LCD monitor - 23"
- Energy Class
- Class A
- Energy Consumption per Year
- 34 kWh
- Power Consumption (On mode)
- 23 W
- USB Hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Pixel Pitch
- 0.265 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Response Time
- 8 ms
- Colour Gamut
- 71.4% NTSC
- Input Connectors
- HDMI, DVI-D, VGA, DisplayPort
- Height, pivot (rotation), swivel, tilt
- Silver, light grey
- 54.4 cm x 22.8 cm x 33.8 cm
- 9.2 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified EPEAT Silver
- DDC/CI
- 3-year warranty
- Display Type
- Energy Class
- Class A
- 34 kWh
- Diagonal Size
- 23"
- Built-in Devices
- USB Hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.265 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Colour Gamut
- 71.4% NTSC
- Response Time
- 8 ms
- Vertical Refresh Rate
- 85 Hz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- WLED
- Controls & Adjustments
- Black level
- Ambient light sensor, XtraView+, CableComp, Rapid Response, No Touch Auto Adjust, cable management cover, sRGB colour management, TileMatrix, carrying handle, HDCP, AmbiBright, Eco-Mode, X-Light Pro, TileComp, DisplaySync Pro, Ambix 4, 14-bit 3D lookup table
- 54.4 cm x 22.8 cm x 33.8 cm - with stand
- 9.2 kg
- HDMI , DVI-D , VGA , DisplayPort , 2 x USB upstream , 3 x USB downstream
Mechanical
- Height Adjustment
- 150 mm
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x VGA cable , 1 x DVI cable - DVI-D to DVI-D , 1 x DisplayPort cable , 1 x USB cable
- DDC/CI
- 23 W
- Power Consumption (Typical)
- 29 Watt
- Power Consumption Stand by
- 1 Watt
- Included Software
- Drivers & Utilities, MultiProfiler
- Dimensions & Weight Details
- With stand - width: 54.4 cm - depth: 22.8 cm - height: 33.8 cm - weight: 9.2 kg
Sustainability Information
- EPEAT Compliant
- EPEAT Silver
- ENERGY STAR Certified
- Limited warranty - parts and labour - 3 years , Limited warranty - backlight - 3 years
- 5 °C
- 35 °C
