NEC MultiSync LCD2090UXi - LCD monitor - 20.1"
Quicklinx: 7T5YWS00 Mfr#: 60001658
The 20" NEC MultiSync LCD2090UXi delivers cutting-edge technologies and design features to the desktops of even the most discerning professional users. This advanced display boasts nearly 30 new features that make this model one of the most intelligent, versatile LCDs to date.
LCD monitor - 20.1"
Native Resolution
1600 x 1200 at 60 Hz
Pixel Pitch
0.255 mm
Brightness
280 cd/m²
Contrast Ratio
700:1
Response Time
16 ms
Colour Support
16.7 million colours
Input Connectors
DVI-I, DVI-D, VGA
Display Position Adjustments
Height, swivel, tilt
Voltage
Image Colour Disclaimer
The displayed product image may be a different colour
43.9 cm x 24.7 cm x 41.6 cm
9.7 kg
Microsoft Certification
Certified for Windows Vista
Environmental Standards
ENERGY STAR Qualified EPEAT Silver
RoHS
3-year warranty
Display Type
LCD monitor / TFT active matrix
Diagonal Size
20.1"
Native Resolution
Pixel Pitch
0.255 mm
Brightness
280 cd/m²
Contrast Ratio
700:1
Colour Support
Response Time
16 ms
Vertical Refresh Rate
85 Hz
Horizontal Refresh Rate
99.4 kHz
Horizontal Viewing Angle
+89 / -89
Vertical Viewing Angle
+89 / -89
Controls & Adjustments
Gamma correction, zoom
Screen saver, XtraView+, Rapid Response, No Touch Auto Adjust, Sync on Green, cable management cover, sRGB colour management, NaViSet, ColorComp, Ambix 3, AmbiBright, Eco-Mode, real-time clock, 12-bit gamma
9.7 kg
1 x DVI-D - 24+1 pin digital DVI , 1 x DVI-I - 24+5 pin combined DVI , 1 x VGA - 15 pin HD D-Sub (HD-15)
Mechanical
VESA Mounting Interface
100 x 100 mm
Wall mountable
Certified for Windows Vista software and devices have undergone compatibility tests for ease-of-use, better performance and enhanced security.
RoHS
Input Voltage
Power Consumption (Typical)
50 Watt
Power Consumption Stand by / Sleep
1 Watt
Included Software
NaViSet
Sustainability Information
EPEAT Compliant
EPEAT Silver
ENERGY STAR Certified
Limited warranty - parts and labour - 3 years
5 °C
35 °C
30 - 80%
