Ultraslim 'Office Cool' design, combining MultiSync trusted performance and quality with new standards of minimalism and Eco Innovation. A 20" wide TN TFT LED backlit display, it is ideal for the corporate that demands style, future proof technology and trusted picture quality with greatest flexibility.
The NEC MultiSync EX201W is a 20" widescreen, lightweight LED-backlit LCD monitor with an ultra-slim bezel depth. It stands out with its stylish minimalist design, rich features and ergonomic adjustability. Rated EPEAT Gold, this display is packed with green features. Its smart sensing technology, such as human sensor and ambient light sensor, make it one of the most power-efficient monitors. The EX201W is an ideal solution for business users on-the-go and small-sized client meetings in that it's portable, flexible and adaptable.
ECO innovation
Low wattage LED, human and luminance sensors to save on power consumption. The slim and lightweight design reduces required resources, packaging materials and transportation energy requirements. -
Future-proof technology
Including two digital inputs (1 x DVI-I and 1 x DisplayPort), 20-inch, 1600x900 wide format and USB for video communication. -
Perfect office set-up
Perfect office set-up the extremely light head of the monitor allows installion in various wall and desk-mounted or dual/multi-monitor solutions delivering all the best in ergonomic standards. -
The vision of the future
The minimalist appearance is a perfect match for modern office desking. The display itself is the dominant part with minimalist lines and a very slim frame, letting the image take precedence. -
Wide 20-inch display with TN technology
1600 x 900, 16:9 format with LED backlight and minimalist design with full OSD functionality. -
Latest inputs
The entire user will need with two digital inputs including DVI and DisplayPort. -
Ambient light sensor with auto brightness
Automatically sets the optimized brightness level according to ambient light and content conditions saving energy and improving viewing. -
Full height adjustability (110 mm)
Together with the swivel, tilt and pivot functionality easily achieve the perfect individual ergonomic set-up in the office. -
Human sensor
Detects the presence of a person in front of the screen and switches on/off automatically depending on the presence of the user saving power.
- NEC MultiSync EX201W - LED monitor - 20"
- LED-backlit LCD monitor - 20"
- Energy Consumption per Year
- 22 kWh
- Power Consumption (On mode)
- 15 W
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- 1600 x 900 at 60 Hz
- Pixel Pitch
- 0.2766 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 25000:1 (dynamic)
- Response Time
- 3.7 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- DVI-I, DisplayPort
- Height, pivot (rotation), swivel, tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 47.5 cm x 21.5 cm x 38.1 cm
- 3.5 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified
- Plug and Play, FCC Class B certified, MPR II, CSA, UL, TUV GS, GOST, cUL, DDC-2B, MPR III, PCT, VESA EDID, CCC, TUV Ergo, DDC/CI, ISO 9241-307, GEEA, ErP Ready
- 3-year warranty
- Display Type
- 22 kWh
- Diagonal Size
- 20"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.2766 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- 3.7 ms
- Vertical Refresh Rate
- 75 Hz
- Horizontal Refresh Rate
- 83 kHz
- Horizontal Viewing Angle
- 176
- Vertical Viewing Angle
- 170
- Backlight Technology
- WLED
- Controls & Adjustments
- Brightness, contrast
- Infrared user sensor, ambient light sensor, cable management cover, Eco-Mode, Auto Brightness Control, Auto Contrast
- Black
- 47.5 cm x 21.5 cm x 38.1 cm - with stand
- 3.5 kg
- DVI-I , DisplayPort , USB downstream , USB upstream (Type B)
Mechanical
- Tilt Angle
- -5/+30
- Swivel Angle
- 340
- Rotation Angle
- 90
- Height Adjustment
- 110 mm
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), USB pass-through connector
- Included Accessories
- Stand
- Cables Included
- 1 x DVI cable - DVI-D to DVI-D , 1 x VGA cable - VGA to DVI-A , 1 x USB cable
- Power Supply
- Internal
- Input Voltage
- 15 W
- Power Consumption (Typical)
- 21 Watt
- Power Consumption Stand by / Sleep
- 0.5 Watt
- Included Software
- Drivers & Utilities
- Dimensions & Weight Details
- With stand - width: 47.5 cm - depth: 21.5 cm - height: 38.1 cm - weight: 3.5 kg , Without stand - width: 47.5 cm - depth: 4.8 cm - height: 27.8 cm - weight: 2.2 kg
- ENERGY STAR Certified
- Limited warranty - 3 years , Limited warranty - backlight - 3 years
- 5 °C
- 35 °C
- 20 - 80%
