Your basket is empty
NEC MultiSync EA294WMi 29" 2560x1080 DVI HDMI DisplayPort USB LED Monitor White
Quicklinx: 993NWS00 Mfr#: 60003415
Diagonal Size: 29in
Max Resolution: 2560 x 1080
Response Time: 14ms
Speakers: Speaker(s)
Interfaces: DisplayPort, DVI, HDMI, VGA (HD-15)
£421.77 ex VAT
£506.12 inc VAT
The NEC MultSync EA294WMi features an extremely thin 29" 21:9 IPS LED backlight panel with a resolution of 2560 x 1080 which results in an ultra-modern and slim design. Due to the format which complies to a dual screen set up of two 19" conventional screens it is an excellent alternative for any multiple screen set up. Ambient light and human sensors enforce the sustainable product concept while offering improved ergonomics.
NEC MultiSync EA294WMi - LED monitor - 29"
LED-backlit LCD monitor - 29"
Energy Class
Class B
Energy Consumption per Year
55 kWh
Power Consumption (On mode)
38 W
USB 2.0 hub
Panel Type
IPS
Aspect Ratio
Widescreen - 21:9
Native Resolution
2560 x 1080
Brightness
300 cd/m²
Contrast Ratio
1000:1
Response Time
14 ms
Colour Support
16.8 million colours
Input Connectors
HDMI, 2xDVI-D, VGA, DisplayPort
Speakers
Integrated
Display Position Adjustments
White
70.58 cm x 23 cm x 41.04 cm
7.5 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified EPEAT Gold
FCC Class B certified, MPR II, CSA, UL, TUV GS, GOST, cUL, DDC-2B, DDC-2Bi, MPR III, PCT, VESA EDID, CCC, TUV Ergo, DDC/CI, RoHS, ISO 9241-307, GEEA, ERP, TCO Displays 6.0
3 years warranty
Display Type
Energy Class
Class B
55 kWh
38 W
Diagonal Size
29"
Viewable Size
29"
Built-in Devices
USB 2.0 hub
Panel Type
IPS
Aspect Ratio
Widescreen - 21:9
Native Resolution
2560 x 1080
Brightness
300 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
14 ms
Vertical Refresh Rate
56 - 75 Hz
Horizontal Refresh Rate
31.5 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
WLED
Controls & Adjustments
Volume, brightness, contrast, colour temperature
Infrared user sensor, ambient light sensor, No Touch Auto Adjust, Intelligent Power Manager (IPM), power off timer, sRGB colour management, HDCP, NaViSet, Eco-Mode, Mobile High-Definition Link (MHL), OSD lock, NaViSet Administrator
White
Image Colour Disclaimer
The displayed product image may be a different colour
70.58 cm x 23 cm x 41.04 cm - with stand
7.5 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
1 Watt
HDMI , 2 x DVI-D (HDCP) , DisplayPort , USB 2.0 upstream , 4 x USB 2.0 downstream , VGA , Headphones
Mechanical
Tilt Angle
-5/+30
Swivel Angle
340
Rotation Angle
90
Height Adjustment
130 mm
Flat Panel Mount Interface
100 x 100 mm
Security lock slot (cable lock sold separately), cable organizer
1 x DisplayPort cable , 1 x USB cable , 1 x audio cable , 1 x VGA cable - VGA to VGA , 1 x DVI cable - DVI-D to DVI-D
Power Supply
Internal
AC 120/230 V
44 Watt
Power Consumption Stand by / Sleep
0.5 Watt
0.4 Watt
Dimensions & Weight Details
With stand - width: 70.58 cm - depth: 23 cm - height: 41.04 cm - weight: 7.5 kg , Without stand - width: 70.58 cm - depth: 6.91 cm - height: 32.18 cm
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
Limited warranty - 3 years , Limited warranty - backlight - 3 years
5 °C
35 °C
20 - 80%
Diagonal Size: 29in
Response Time: 14ms
Interfaces: DVI
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: NEC
Price Range Ex VAT: 300 - 500
