NEC MultiSync EA294WMi 29" 2560x1080 DVI HDMI DisplayPort USB LED Monitor Black
Quicklinx: 993PWS00 Mfr#: 60003417
The NEC MultSync EA294WMi features an extremely thin 29" 21:9 IPS LED backlight panel with a resolution of 2560 x 1080 which results in an ultra-modern and slim design. Due to the format which complies to a dual screen set up of two 19" conventional screens it is an excellent alternative for any multiple screen set up. Ambient light and human sensors enforce the sustainable product concept while offering improved ergonomics.
  • Ambient light sensor
    With auto brightness function always sets optimized brightness level according to ambient light and content conditions.
  • Ergonomic office
    Full height adjustability, swivel, tilt and pivot functionality ensures perfect individual ergonomic set-up.
  • Human sensor
    It detects the presence of a person in front of the screen; display switches on/off automatically depending on the presence of the user.
  • Ultra-modern and slim design
    The product design is discrete and puts priority on the screen image and function. The 29" 21:9 picture format is the perfect alternative for a dual 19" conventional screen set up.
  • Ambient light and human sensors
    The sensor technologies provide a perfect image with minimum power consumption.
NEC MultiSync EA294WMi - LED monitor - 29"
LED-backlit LCD monitor - 29"
Energy Class
Class B
Energy Consumption per Year
55 kWh
Power Consumption (On mode)
38 W
USB 2.0 hub
Panel Type
IPS
Aspect Ratio
21:9
Native Resolution
2560 x 1080
Brightness
300 cd/m²
Contrast Ratio
1000:1
Response Time
14 ms
Colour Support
16.8 million colours
Input Connectors
HDMI, 2xDVI-D, VGA, DisplayPort
Speakers
Integrated
Display Position Adjustments
Voltage
AC 120/230 V
70.58 cm x 23 cm x 41.04 cm
7.5 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified EPEAT Gold
FCC Class B certified, MPR II, CSA, UL, TUV GS, GOST, cUL, DDC-2B, DDC-2Bi, MPR III, PCT, VESA EDID, CCC, TUV Ergo, DDC/CI, RoHS, ISO 9241-307, GEEA, ERP
3-year warranty
Display Type
Energy Class
Class B
55 kWh
Diagonal Size
29"
Built-in Devices
USB 2.0 hub
Panel Type
IPS
Aspect Ratio
21:9
Native Resolution
2560 x 1080
Brightness
300 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
14 ms
Vertical Refresh Rate
56 - 75 Hz
Horizontal Refresh Rate
31.5 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
WLED
Controls & Adjustments
Volume, brightness, contrast, colour temperature
Infrared user sensor, ambient light sensor, No Touch Auto Adjust, Intelligent Power Manager (IPM), power off timer, sRGB colour management, HDCP, NaViSet, Eco-Mode, Mobile High-Definition Link (MHL), OSD lock, NaViSet Administrator
70.58 cm x 23 cm x 41.04 cm - with stand
7.5 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
1 Watt
HDMI , 2 x DVI-D (HDCP) , DisplayPort , USB 2.0 upstream , 4 x USB 2.0 downstream , VGA , Headphones
Mechanical
Tilt Angle
-5/+30
Swivel Angle
340
Rotation Angle
90
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), cable organizer
1 x DisplayPort cable , 1 x USB cable , 1 x audio cable , 1 x VGA cable - VGA to VGA , 1 x DVI cable - DVI-D to DVI-D
Power Supply
Internal
Input Voltage
AC 120/230 V
38 W
Power Consumption (Typical)
44 Watt
Power Consumption Stand by / Sleep
0.5 Watt
0.4 Watt
Dimensions & Weight Details
With stand - width: 70.58 cm - depth: 23 cm - height: 41.04 cm - weight: 7.5 kg , Without stand - width: 70.58 cm - depth: 6.91 cm - height: 32.18 cm
Sustainability Information
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
Limited warranty - 3 years , Limited warranty - backlight - 3 years
5 °C
35 °C
20 - 80%
