NEC MultiSync EA244WMi features an extremely thin LED backlight panel with IPS technology which results in an ultramodern and slim design in combination with a premium feature set for the corporate office use. Ambient light and human sensors enforce the sustainable product concept while offering improved ergonomics with 130 mm height adjustability. Moreover the display offers broad connectivity with four inputs DisplayPort, HDMI, DVI-D and D-Sub. Thanks to its excellent IPS image quality with wide viewing angles in 16:10 screen format, it offers a high level of ergonomic comfort. Ideal for the corporate that demand style and future proof technology
Ultra-modern and slim design
The product design is discrete and puts priority on the screen image and function. -
The sensor technologies provide a perfect image with minimum power consumption. -
Improved ergonomics
The ergonomic stand with 130 mm height adjustability allows greatest set-up flexibility.
- NEC MultiSync EA244WMi - LED monitor - 24"
- LED-backlit LCD monitor - 24"
- Energy Class
- Class A+
- Energy Consumption per Year
- 31 kWh
- Power Consumption (On mode)
- 21 W
- USB Hub
- Panel Type
- IPS
- Aspect Ratio
- 16:10
- Native Resolution
- 1920 x 1200 at 60 Hz
- Pixel Pitch
- 0.27 mm
- Brightness
- 350 cd/m²
- Contrast Ratio
- 1000:1 / 25000:1 (dynamic)
- Response Time
- 5 ms
- Colour Support
- 16.8 million colours
- Input Connectors
- HDMI, DVI-D, VGA, DisplayPort
- Speakers
- Integrated
- Height, pivot (rotation), swivel, tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- White
- 55.62 cm x 23 cm x 40.89 cm
- 7.6 kg
- Environmental Standards
- ENERGY STAR Qualified
- Plug and Play, FCC Class B certified, MPR II, CSA, UL, TUV GS, GOST, cUL, DDC-2B, PCT, TUV Ergo, DDC/CI, RoHS, ISO 9241-307, GEEA
- 3-year warranty
- Display Type
- Energy Class
- Class A+
- 31 kWh
- Diagonal Size
- 24"
- Viewable Size
- 24.1"
- Built-in Devices
- USB Hub
- Panel Type
- IPS
- Aspect Ratio
- 16:10
- Native Resolution
- Pixel Pitch
- 0.27 mm
- Brightness
- 350 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- 5 ms
- Vertical Refresh Rate
- 56 - 60 Hz
- Horizontal Refresh Rate
- 31.5 - 77 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- WLED
- Controls & Adjustments
- Volume, brightness, contrast, colour temperature
- Infrared user sensor, No Touch Auto Adjust, ErgoDesign, Intelligent Power Manager (IPM), power off timer, sRGB colour management, HDCP, NaViSet, Eco-Mode, touch keys, ControlSync, OSD lock
- White
- 7.6 kg
Audio
- Speakers - stereo - integrated
- Output Power / Channel
- 1 Watt
- DisplayPort (HDCP) , HDMI , DVI-D (HDCP) , VGA , USB upstream (Type B) , 4 x USB 2.0 downstream , Audio line-in , Headphones
Mechanical
- Tilt Angle
- -5/+30
- Swivel Angle
- 340
- Rotation Angle
- 90
- Height Adjustment
- 130 mm
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), cable organizer
- Cables Included
- 1 x VGA cable - VGA to VGA , 1 x DVI cable - DVI-D to DVI-D , 1 x audio cable , 1 x USB cable
- Power Supply
- Internal
- Input Voltage
- 21 W
- Power Consumption (Typical)
- 29 Watt
- Power Consumption Stand by / Sleep
- 0.47 Watt
- 0.47 Watt
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - parts and labour - 3 years , Limited warranty - backlight - 3 years
- 5 °C
- 35 °C
- 20 - 80%
