For affordable digital signage applications yet with impressive screen performance, the MultiSync E654 features the edge LED backlight technology for an ultra slim design, light weight and very low power consumption.
Reduced installation and operating costs
Featuring LED backlight technology the display is highly energy efficient with low power consumption, longer backlight lifetime and a lighter design for easy and flexible transportation, mounting and integration. -
Slim design and integrated speakers
The aesthetic design is pleasing to the eye and enables easy, low cost installation. -
Future ready connectivity
It is featuring multiple industry standard digital and analog signal inputs for flexible integration into AV infrastructures.
- NEC E654 65" LED-backlit LCD display - for digital signage
- Product Type
- LED-backlit LCD flat panel display
- Diagonal Class
- 65"
- Commercial Use
- Yes - digital signage
- Black
- Resolution
- 1920 x 1080
- Input Video Formats
- 1080/24p, 1080/60i, 480/60p, 720/60p, 1080/60p, 1080/30p, 480/60i
- Video Interface
- Component, composite, HDMI
- HDMI Ports Qty
- 3 ports
- PC Interface
- VGA (HD-15)
- Technology
- S-PVA
- LCD Backlight Technology
- Edge-lit LED
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Speaker System
- 2 speakers
- USB
- Included Accessories
- Remote control
- Energy Class
- Class B
- 260 Watt
- Power Consumption (On mode)
- 208 W
- Power Consumption Stand by
- 0.5 Watt
- Energy Consumption per Year
- 304 kWh
- Dimensions (WxDxH) - without stand
- 146.7 cm x 10 cm x 87.2 cm
- 30 kg
- Environmental Standards
- ENERGY STAR Qualified
- 3-year warranty
- Product Type
- Energy Class
- Class B
- 260 Watt
- 208 W
- 304 kWh
- Diagonal Class
- 65"
- Commercial Use
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Video Interface
- HDMI Ports Qty
- 3 ports
- PC Interface
- VGA (HD-15)
- Dimensions
- Without stand
- 146.7 cm
- 10 cm
- 87.2 cm
- 30 kg
- Enclosure Colour
- Black
Display
- LCD Display Technology
- S-PVA
- Resolution
- 1920 x 1080
- 16:9
- Edge-lit LED
- Image Contrast Ratio
- 4000:1
- Brightness
- 350 cd/m²
- Viewing Angle
- 176 degrees
- Viewing Angle (Vertical)
- 176 degrees
- Response Time
- 6.5 ms
Stands & Mounts
- Flat Panel Mount Interface
- 400 x 400 mm
Video Features
- Supported Computer Resolutions
- 1366 x 768, 1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA), 1280 x 720, 720 x 400, 1920 x 1080, 1280 x 800
Media Player
- Supported Pictures Formats
- JPG
- USB Port
- USB Ports Qty
- 1
Remote Control
- Remote control
Audio System
- Speaker System
- 2 speakers
- Output Power / Total
- 20 Watt
- Speakers
- 2 x main channel speaker - 10 Watt
- Connector Type
- VGA input , 3 x HDMI , SPDIF output , Serial , USB , Composite video / component video input , Audio input , Audio input
- Cables Included
- VGA cable
- FCC Class B certified, CSA, UL, C-Tick, cUL, VESA DPMS, VESA FDMI, PSB, RoHS
Sustainability Information
- ENERGY STAR Certified
- ENERGY STAR Version
- 6.0
- 0.5 Watt
- Limited warranty - 3 years ¦ Limited warranty - backlight - 3 years
- 0 °C
- 40 °C
- 10 - 80%
