NEC MultiSync E507Q 50" 3840x2160 8ms VGA HDMI LED Large Format Display
Quicklinx: F8D3WS00 Mfr#: 60004548
The NEC MultiSync impressively displays your retail content and is easy enough to use in daily meetings. You'll enjoy the native content playback - which can be used automatically via the integrated playback tool. For instant meeting start-ups, the display comes equipped with auto wake-up, which wakes up the screen once a notebook is connected.
  • Reduced installation and operating costs
    Highly energy-efficient LED backlit display ensures low power consumption, longer backlight lifetime and lighter design for easy transportation, mounting and integration.
  • Effortless content playback
    The integrated USB media player supports various image video file formats for effortless and standalone content playback.
  • Slim design and integrated speakers
    The aesthetic design is pleasing to the eye and enables easy, lower cost installation.
  • Standalone operation
    The display is designed for straightforward standalone operation due to integrated USB media player, speakers and scheduling functionality.
NEC MultiSync E507Q 50" Class (49.5" viewable) LED-backlit LCD display - 4K - for digital signage
LED-backlit LCD flat panel display
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/428562
Diagonal Class
50"
Diagonal Size
49.5"
Commercial Use
Yes - digital signage
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
HDR Format
HLG10
HDR Technology
Perceptual Quantizer (PQ)
Frame Rate & Enhancement Technology
60 Hz Refresh Rate
Video Interface
Component, composite, HDMI
HDMI Ports Qty
3 ports
LAN
PC Interface
VGA (HD-15)
VA
LCD Backlight Technology
Direct-lit LED
Image Aspect Ratio
16:9
TV Tuner
No tuner
Commercial Features
SNMP support
Speaker System
2 speakers
USB
Remote control
Energy Class
Class G
97 watt
Power Consumption (On mode)
88 W
Power Consumption Stand by
0.5 watt
Energy Consumption per Year
133 kWh
112.3 cm x 7.7 cm x 64.6 cm
12.4 kg
Environmental Standards
ENERGY STAR Qualified
3-year warranty
Energy Class
Class G
97 watt
88 W
88 kWh/1000h
133 kWh
Diagonal Class
50"
Diagonal Size
49.5"
Commercial Use
HDR Capable
HDR Format
HLG10
HDR Technology
TV Tuner
No tuner
TV Tuner Presence
No
Sensors
Ambient light sensor (ALS)
Video Interface
HDMI Ports Qty
3 ports
PC Interface
VGA (HD-15)
Modes
Landscape mode
Dimensions
Without stand
112.3 cm
7.7 cm
64.6 cm
12.4 kg
Display
LCD Display Technology
VA
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Image Aspect Ratio
16:9
60 Hz Refresh Rate
Direct-lit LED
Coating
2% haze
Image Contrast Ratio
4000:1
Brightness
350 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Response Time
8 ms
Commercial Features
SNMP support
Certified for 16/7 Continuous Operation, Scheduler, NaViSet Administrator 2, Crestron Roomview support
Stands & Mounts
Flat Panel Mount Interface
400 x 200 mm
VESA Compatibility
Media Player
Supported Video Formats
MPEG-2, Motion-JPEG, WMV, AVI, MKV, H.264, H.263, MPG, MPEG, H.265
Supported Audio Formats
MP3, WMA, AC3, AAC, LPCM, WMA Pro, MP4
Supported Pictures Formats
JPG
USB Port
USB Ports Qty
1
Remote Control
Remote control
Audio System
Equaliser
Speaker System
2 speakers
Output Power / Total
20 watt
Speakers
2 x main channel speaker - 10 watt
Network & Internet Multimedia
LAN
Connector Type
VGA input , Composite video / component video input , Audio output , 3 x HDMI , SPDIF output , Serial , Audio input , USB 2.0 , LAN
HDMI cable
UL, VCCI, cUL, TUV S, PSB, FCC, CEC, EMC Class B, RCM
Sustainability Information
ENERGY STAR Certified
0.5 watt
Limited warranty - 3 years , Limited warranty - backlight - 3 years
10 - 80%
