The NEC MultiSync impressively displays your retail content and is easy enough to use in daily meetings. You'll enjoy the native content playback - which can be used automatically via the integrated playback tool. For instant meeting start-ups, the display comes equipped with auto wake-up, which wakes up the screen once a notebook is connected.
Reduced installation and operating costs
Highly energy-efficient LED backlit display ensures low power consumption, longer backlight lifetime and lighter design for easy transportation, mounting and integration. -
Effortless content playback
The integrated USB media player supports various image video file formats for effortless and standalone content playback. -
Slim design and integrated speakers
The aesthetic design is pleasing to the eye and enables easy, lower cost installation. -
Standalone operation
The display is designed for straightforward standalone operation due to integrated USB media player, speakers and scheduling functionality.
- NEC MultiSync E507Q 50" Class (49.5" viewable) LED-backlit LCD display - 4K - for digital signage
- Product Type
- LED-backlit LCD flat panel display
- Energy Label QR Code URL
- Https://eprel.ec.europa.eu/qr/428562
- Diagonal Class
- 50"
- Diagonal Size
- 49.5"
- Commercial Use
- Yes - digital signage
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- HDR Format
- HLG10
- HDR Technology
- Perceptual Quantizer (PQ)
- Frame Rate & Enhancement Technology
- 60 Hz Refresh Rate
- Video Interface
- Component, composite, HDMI
- HDMI Ports Qty
- 3 ports
- Connectivity
- LAN
- PC Interface
- VGA (HD-15)
- Technology
- VA
- LCD Backlight Technology
- Direct-lit LED
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Commercial Features
- SNMP support
- Speaker System
- 2 speakers
- USB
- Included Accessories
- Remote control
- Energy Class
- Class G
- 97 watt
- Power Consumption (On mode)
- 88 W
- Power Consumption Stand by
- 0.5 watt
- Energy Consumption per Year
- 133 kWh
- Dimensions (WxDxH) - without stand
- 112.3 cm x 7.7 cm x 64.6 cm
- 12.4 kg
- Environmental Standards
- ENERGY STAR Qualified
- 3-year warranty
- Product Type
- Energy Class
- Class G
- 97 watt
- 88 W
- Power Consumption SDR (On mode)
- 88 kWh/1000h
- 133 kWh
- Diagonal Class
- 50"
- Diagonal Size
- 49.5"
- Commercial Use
- HDR Capable
- HDR Format
- HLG10
- HDR Technology
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Sensors
- Ambient light sensor (ALS)
- Video Interface
- HDMI Ports Qty
- 3 ports
- PC Interface
- VGA (HD-15)
- Modes
- Landscape mode
- Dimensions
- Without stand
- 112.3 cm
- 7.7 cm
- 64.6 cm
- 12.4 kg
Display
- LCD Display Technology
- VA
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- 16:9
- Direct-lit LED
- Coating
- 2% haze
- Image Contrast Ratio
- 4000:1
- Brightness
- 350 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Response Time
- 8 ms
- SNMP support
- Certified for 16/7 Continuous Operation, Scheduler, NaViSet Administrator 2, Crestron Roomview support
Stands & Mounts
- Flat Panel Mount Interface
- 400 x 200 mm
- VESA Compatibility
Media Player
- Supported Video Formats
- MPEG-2, Motion-JPEG, WMV, AVI, MKV, H.264, H.263, MPG, MPEG, H.265
- Supported Audio Formats
- MP3, WMA, AC3, AAC, LPCM, WMA Pro, MP4
- Supported Pictures Formats
- JPG
- USB Port
- USB Ports Qty
- 1
Remote Control
- Remote control
Audio System
- Equaliser
- Speaker System
- 2 speakers
- Output Power / Total
- 20 watt
- Speakers
- 2 x main channel speaker - 10 watt
Network & Internet Multimedia
- Connectivity
- LAN
- Connector Type
- VGA input , Composite video / component video input , Audio output , 3 x HDMI , SPDIF output , Serial , Audio input , USB 2.0 , LAN
- Cables Included
- HDMI cable
- UL, VCCI, cUL, TUV S, PSB, FCC, CEC, EMC Class B, RCM
Sustainability Information
- ENERGY STAR Certified
- 0.5 watt
- Limited warranty - 3 years , Limited warranty - backlight - 3 years
- 0 °C
- 40 °C
- 10 - 80%
