In a digitized world, signage no longer is static. Information transfer via digital posters and information boards are common methods of information transfer. With E506 you can boost your business at low TCO, but with high reliability. Information where the audience stands close is perfectly transferred on this large screen. With the integrated media player, the display is designed for simple signage usage directly from a USB drive and once installed starts playing the content automatically at a certain time with the embedded auto start time schedule function. In this way the display helps you saving time and money.
- NEC MultiSync E506 E Series - 50" LED display
- Product Type
- LED-backlit LCD flat panel display
- Diagonal Class
- 50"
- Commercial Use
- Yes - digital signage
- Black
- Resolution
- 1920 x 1080
- Display Format
- 1080p (Full HD)
- Input Video Formats
- 1080/24p, 1080/60i, 480/60p, 720/60p, 1080/50i, 720/50p, 576/50p, 1080/60p, 1080/30p, 480/60i, 576/50i
- Motion Enhancement Technology
- 60 Hz Refresh Rate
- Video Interface
- Component, composite, HDMI
- HDMI Ports Qty
- 3 ports
- PC Interface
- VGA (HD-15)
- Technology
- S-PVA
- LCD Backlight Technology
- LED backlight - direct-lit LED
- Image Aspect Ratio
- 16:9
- Speaker System
- 2 speakers
- USB
- Remote Control
- Standard remote
- Voltage
- AC 100 - 240 V (50/60 Hz)
- Energy Class
- Class A
- 79 Watt
- Power Consumption (On mode)
- 84 W
- Energy Consumption per Year
- 123 kWh
- Dimensions (WxDxH) - without stand
- 112.36 cm x 7.7 cm x 64.67 cm
- 12.88 kg
- Environmental Standards
- ENERGY STAR Qualified
- 3 years warranty
- Product Type
- Energy Class
- Class A
- 79 Watt
- 84 W
- 123 kWh
- Diagonal Class
- 50"
- Commercial Use
- Series
- E Series
- Video Interface
- HDMI Ports Qty
- 3 ports
- PC Interface
- VGA (HD-15)
- Modes
- Landscape mode, Eco mode
- Dimensions
- Without stand
- 112.36 cm
- 7.7 cm
- 64.67 cm
- 12.88 kg
- Enclosure Colour
- Black
Display
- LCD Display Technology
- S-PVA
- Resolution
- 1920 x 1080
- Display Format
- 1080p (Full HD)
- 16:9
- Image Contrast Ratio
- 3000:1
- Brightness
- 350 cd/m²
- Viewing Angle
- 176 degrees
- Viewing Angle (Vertical)
- 176 degrees
- Response Time
- 8 ms
- 12/7 continious operation
Stands & Mounts
- Stand
- Optional
- Flat Panel Mount Interface
- 400 x 200 mm
Video Features
- Supported Computer Resolutions
- 1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA), 1280 x 1024 (SXGA), 1280 x 720, 1920 x 1080, 1280 x 800
Media Player
- Supported Video Formats
- MPEG-1, MPEG-2, MPEG-4, Motion-JPEG, AVI, MKV, TS, H.264, PS, MPG
- Supported Audio Formats
- MP3, AC3, MP2
- Supported Pictures Formats
- JPEG
- USB Port
- USB Ports Qty
- 1
Remote Control
- Standard remote
Audio System
- Speaker System
- 2 speakers
- Output Power / Total
- 20 Watt
- Speakers
- 2 x main channel speaker - built-in - 10 Watt
- Connector Type
- 3 x HDMI , USB , RS-232C , Audio input , VGA input , Composite video / component video / audio input , SPDIF output
- Cables Included
- VGA cable
- FCC Class B certified, CSA, UL, C-Tick, cUL, SASO, VESA DPMS, PSB, RoHS, REACH
- ENERGY STAR Certified
- ENERGY STAR Version
- 7.0
- Power Device
- Power supply
- Nominal Voltage
- Power Consumption Stand by
- 0.5 Watt
- Limited warranty - parts and labour - 3 years , Limited warranty - backlight - 3 years
Dimensions & Weight Details
- Dimensions & Weight Details
- Panel without stand - 112.36 cm x 25.5 cm x 68.37 cm x 13.38 kg , Panel with stand - 112.36 cm x 7.7 cm x 64.67 cm x 12.88 kg
- 0 °C
- 40 °C
- 10 - 80%
