NEC MultiSync E506 50" 1920x1080 VGA HDMI LED Large Format Display
Quicklinx: D34JWS00 Mfr#: 60004022
  • 1080p
In a digitized world, signage no longer is static. Information transfer via digital posters and information boards are common methods of information transfer. With E506 you can boost your business at low TCO, but with high reliability. Information where the audience stands close is perfectly transferred on this large screen. With the integrated media player, the display is designed for simple signage usage directly from a USB drive and once installed starts playing the content automatically at a certain time with the embedded auto start time schedule function. In this way the display helps you saving time and money.
  • Reduced installation and operating costs
    Highly energy efficient LED backlit display ensures low power consumption, longer backlight lifetime and lighter design for easy transportation, mounting and integration.
  • Slim design and integrated speakers
    The aesthetic design is pleasing to the eye and enables easy, low cost installation.
  • Effortless content playback
    The integrated USB media player supports various image video file formats for effortless and standalone content playback.
  • Professional integration
    Enriched with essential RS232 functionality, IR and button lock out as well as digital audio output S/PDIF, the display can easily be integrated into professional applications in public environments.
  • Standalone operation
    The display is designed for straightforward standalone operation due to integrated USB media player, speakers and scheduling functionality.
NEC MultiSync E506 E Series - 50" LED-backlit LCD display - Full HD - for digital signage
LED-backlit LCD flat panel display
Diagonal Class
50"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p
Input Video Formats
1080/24p, 1080/60i, 480/60p, 720/60p, 1080/50i, 720/50p, 576/50p, 1080/60p, 1080/30p, 480/60i, 576/50i
Frame Rate & Enhancement Technology
60 Hz Refresh Rate
Video Interface
Component, composite, HDMI
HDMI Ports Qty
3 ports
PC Interface
VGA (HD-15)
S-PVA
LCD Backlight Technology
Direct-lit LED
Image Aspect Ratio
16:9
Speaker System
2 speakers
USB
Remote control
Voltage
AC 100 - 240 V (50/60 Hz)
Energy Class
Class A
79 Watt
Power Consumption (On mode)
84 W
Power Consumption Stand by
0.5 Watt
Energy Consumption per Year
123 kWh
112.36 cm x 7.7 cm x 64.67 cm
12.88 kg
Environmental Standards
ENERGY STAR Qualified
3-year warranty
Energy Class
Class A
79 Watt
84 W
123 kWh
Diagonal Class
50"
Commercial Use
Series
E Series
TV Tuner Presence
No
Video Interface
HDMI Ports Qty
3 ports
PC Interface
VGA (HD-15)
Modes
Landscape mode, Eco mode
Dimensions
Without stand
112.36 cm
7.7 cm
64.67 cm
12.88 kg
Enclosure Colour
Display
LCD Display Technology
S-PVA
Resolution
1920 x 1080
Display Format
1080p
Image Aspect Ratio
16:9
60 Hz Refresh Rate
Direct-lit LED
Image Contrast Ratio
3000:1
Brightness
350 cd/m²
Viewing Angle
176 degrees
Viewing Angle (Vertical)
176 degrees
Response Time
8 ms
12/7 continious operation
Stands & Mounts
Stand
Optional
Flat Panel Mount Interface
400 x 200 mm
Video Features
Input Video Formats
Supported Computer Resolutions
1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA), 1280 x 1024 (SXGA), 1280 x 720, 1920 x 1080, 1280 x 800
Media Player
Supported Video Formats
MPEG-1, MPEG-2, MPEG-4, Motion-JPEG, AVI, MKV, TS, H.264, PS, MPG
Supported Audio Formats
MP3, AC3, MP2
Supported Pictures Formats
JPEG
USB Port
USB Ports Qty
1
Remote Control
Remote control
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
Speakers
2 x main channel speaker - 10 Watt
Connector Type
3 x HDMI , USB , RS-232C , Audio input , VGA input , Composite video / component video / audio input , SPDIF output
VGA cable
FCC Class B certified, CSA, UL, C-Tick, cUL, SASO, VESA DPMS, PSB, RoHS, REACH
Sustainability Information
ENERGY STAR Certified
ENERGY STAR Version
7.0
Power supply
Input Voltage
0.5 Watt
Limited warranty - parts and labour - 3 years , Limited warranty - backlight - 3 years
Dimensions & Weight Details
Panel without stand - 112.36 cm x 25.5 cm x 68.37 cm x 13.38 kg , Panel with stand - 112.36 cm x 7.7 cm x 64.67 cm x 12.88 kg
10 - 80%
