NEC MultiSync E231W - LED monitor - Full HD (1080p) - 23"
Quicklinx: 7T5HWS00 Mfr#: 60002933
Take your environmental initiatives to the level with the 23" NEC MultiSync E231W, a widescreen LCD desktop monitor that enhances your desktop computing with bar-setting, eco-friendly benefits. The E231W features an LED-backlit panel that provides the same brightness as other panel types while using 35% less power. Compared to previous generation NEC LCDs, this model consumes less power overall, radiates less heat, uses less packaging, weighs less, utilizes recycled plastics in its production and is free of hazardous materials such as mercury, halogen and arsenic. These advantages, combined with an ergonomic design and a high-contrast screen, make this model ideal for enterprise environments.
  • XtraView
    NEC MultiSync E231W delivers wide viewing angles of up to 176º horizontally and vertically (up to 88º up, down, left and right) with less color shift and without any glare, reflection or distortion.
  • Ambix
    NEC MultiSync E231W allows up to 3 inputs VGA, DVI-I and DVI-D to be connected to a single monitor. It also allows for each of the three signals to be displayed with the press of a button.
  • Rapid response
    NEC MultiSync E231W provides for uninterrupted display of full motion video with response times as quick as 4ms. It delivers streaming video without noticeable ghosting or blurring, while achieving as many as 250 frames per second (fps). This remarkably quick motion makes displays better than ever for gaming and video applications such as presentations and streaming web video.
  • Eco-mode
    Eco-mode conserves energy by allowing you to define a setting for the backlight at a 50 or 75% brightness level. Also calculates power saving in watts per hour.
  • NTAA
    No Touch Auto Adjust (NTAA) allows the monitor's image settings to be automatically adjusted to optimal settings upon initial power on.
  • sRGB
    A recommended default color setting that helps achieve a consistent color environment for PC-based applications. With sRGB, the image colors seen by the user on his/her screen can be reproduced elsewhere, such as printers.
  • OSD
    On Screen Display (OSD) controls allow users to quickly and easily adjust all elements of their screen image via simple-to-use on screen menus.
LED-backlit LCD monitor - 23"
Energy Class
Class A
Energy Consumption per Year
34 kWh
Power Consumption (On mode)
23 W
Panel Type
TN
Native Resolution
Pixel Pitch
0.265 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 25000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA, DisplayPort
Display Position Adjustments
Voltage
AC 120/230 V
White, silver
55 cm x 21.4 cm x 38.1 cm
6.2 kg
Microsoft Certification
Certified for Windows Vista
Environmental Standards
ENERGY STAR Qualified
FCC Class B certified, MPR II, CSA, UL, TUV GS, GOST, cUL, DDC-2Bi, MPR III, PCT, CCC, TUV Ergo, ISO 9241-307, GEEA, ErP Ready
3-year warranty
Display Type
Energy Class
Class A
34 kWh
Diagonal Size
23"
Panel Type
TN
Native Resolution
Pixel Pitch
0.265 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
75 Hz
Horizontal Refresh Rate
83 kHz
Horizontal Viewing Angle
176
Vertical Viewing Angle
170
Backlight Technology
WLED
Controls & Adjustments
Brightness, contrast, H/V position, colour balance
Ambient light sensor, ErgoDesign, Eco-Mode
White, silver
55 cm x 21.4 cm x 38.1 cm - with stand
6.2 kg
VGA , DVI-D , DisplayPort
Mechanical
Tilt Angle
25
Rotation Angle
90
Height Adjustment
110 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), cable organizer
1 x DVI cable , 1 x VGA cable
Certified for Windows Vista software and devices have undergone compatibility tests for ease-of-use, better performance and enhanced security.
Power Supply
Internal
Input Voltage
AC 120/230 V
23 W
Power Consumption (Typical)
28 Watt
Power Consumption Stand by / Sleep
0.34 Watt
Dimensions & Weight Details
Without stand - width: 55 cm - depth: 7.1 cm - height: 32.9 cm , With stand - width: 55 cm - depth: 21.4 cm - height: 38.1 cm - weight: 6.2 kg
Sustainability Information
ENERGY STAR Certified
Limited warranty - 3 years , Limited warranty - backlight - 3 years
5 °C
35 °C
20 - 80%
