NEC MultiSync E222W - LCD display - TFT - 22" - widescreen - 1680 x 1050
Quicklinx: 7PVZWS00 Mfr#: 60002663
Great flexibility and strong ergonomic features characterize the NEC MultiSync E222W as the ideal entry-level wide-format display for daily office applications. The 22" display offers an improved height adjustment capability as well as pivot functionality. In addition to the ecological advantages, users benefit from the easy-to-use OSD buttons with an intuitive menu system and excellent economic performance. The NEC MultiSync E222W perfectly meets the requirements of corporate office environments as well as for the SOHO and SMB sectors.
Ensuring a low total cost of ownership (TCO), the NEC MultiSync E222W has been equipped with Eco mode and several functions that limit its power consumption. These include automatic stand-by and power-off timer functions, which, along with operating the display in Eco mode help to minimize power consumption.
The NEC Multisync E222W offers superior ergonomics with improved height-adjustability. VESA mounting allows for flexible installation options, whilst a practical hand grip to the rear of the device provides a convenient means for its transport.
NEC MultiSync E222W - LCD monitor - 22"
LCD monitor - 22"
Panel Type
TN
Aspect Ratio
16:10
Native Resolution
1680 x 1050 at 60 Hz
Pixel Pitch
0.282 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA
Display Position Adjustments
Height, swivel, tilt
Voltage
Image Colour Disclaimer
The displayed product image may be a different colour
50.8 cm x 21.4 cm x 38.5 cm
6.8 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified EPEAT Silver
FCC Class B certified, MPR II, CSA, UL, TUV GS, GOST, cUL, DDC-2B, DDC-2Bi, ISO 13406-2, MPR III, PCT, VESA EDID, CCC, TUV Ergo, DDC/CI, RoHS, GEEA
3-year warranty
Display Type
LCD monitor / TFT active matrix
Diagonal Size
22"
Panel Type
TN
Aspect Ratio
16:10
Native Resolution
Pixel Pitch
0.282 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
5 ms
Vertical Refresh Rate
75 Hz
Horizontal Refresh Rate
82 kHz
Horizontal Viewing Angle
176
Vertical Viewing Angle
170
Controls & Adjustments
Brightness, contrast, colour temperature
No Touch Auto Adjust, ErgoDesign, Intelligent Power Manager (IPM), power off timer, HDCP, NaViSet, Eco-Mode
6.8 kg
DVI-D , VGA
Mechanical
VESA Mounting Interface
100 x 100 mm
1 x DVI cable , 1 x VGA cable , 1 x power cable
Power Supply
Internal
Input Voltage
Power Consumption (Typical)
40 Watt
Power Consumption Stand by / Sleep
2 Watt
Included Software
Drivers & Utilities
EPEAT Compliant
EPEAT Silver
ENERGY STAR Certified
Limited warranty - parts and labour - 3 years , Limited warranty - backlight - 3 years
5 °C
35 °C
20 - 80%
