NEC MultiSync E201W - LED monitor - 20"
Quicklinx: 7T5DWS00 Mfr#: 60002818
The E201W is an energy saving 20" 16:9 format monitor. It offers LED backlight, DisplayPort connectivity and full adjustability. Low power consumption and low operating costs make the display perfect for use in the professional office environment. Outstanding ergonomic qualities and intelligent features such as the ambient light sensor make it very user-friendly and help to increase productivity. It's ideal for large corporates and medium sized businesses for the standard office use with environmental attention.
E201W sets new standard in environmental compatibility. The ambient light sensor serves to increase energy saving even further. It measures the ambient light and adjusts the screen to the optimum brightness automatically without any manual settings being required. The use of recycling plastic for the monitor housing and of mercury-free materials fulfill the demands of the "NEC Green Vision" campaign.
The connection options ensure leading-edge compatibility. With a DisplayPort, a DVI-D as well as an analog interface, the NEC MultiSync E201W provides outstanding connectivity and the optimum basis for all business applications.
The eco-friendly displays further extends comprehensive range for the corporate sector. It helps to reduce the running costs throughout the display's entire lifetime and the features make daily operations simpler and more productive.
  • Ambient light sensor
    With auto brightness function it always sets optimized brightness level according to ambient light and content conditions.
  • VESA mount
    It allows to install the monitor via various mounting solutions, stand has a quick release for faster installations.
  • Ergonomic office
    Full height adjustability, swivel, tilt and pivot functionality ensure perfect individual ergonomic setup.
LED-backlit LCD monitor - 20"
Energy Class
Class A
Energy Consumption per Year
26 kWh
Power Consumption (On mode)
18 W
Aspect Ratio
16:9
Native Resolution
1600 x 900 at 60 Hz
Pixel Pitch
0.267 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 25000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA, DisplayPort
Display Position Adjustments
Voltage
AC 120/230 V
White, silver
55 cm x 21.4 cm x 38.1 cm
5.4 kg
Environmental Standards
ENERGY STAR Qualified
FCC Class B certified, MPR II, CSA, UL, TUV GS, GOST, cUL, MPR III, PCT, CCC, TUV Ergo, ISO 9241-307, GEEA, ErP Ready
3-year warranty
Display Type
Energy Class
Class A
26 kWh
Diagonal Size
20"
Aspect Ratio
16:9
Native Resolution
1600 x 900 at 60 Hz
Pixel Pitch
0.267 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
75 Hz
Horizontal Refresh Rate
82.3 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
WLED
Controls & Adjustments
Brightness, contrast, H/V position, colour balance
Ambient light sensor, ErgoDesign, Intelligent Power Manager (IPM), Eco-Mode
White, silver
55 cm x 21.4 cm x 38.1 cm - with stand
5.4 kg
VGA , DVI-D , DisplayPort
Mechanical
Tilt Angle
25
Rotation Angle
90
Height Adjustment
110 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), cable organizer
1 x DVI cable , 1 x VGA cable
Power Supply
Internal
Input Voltage
AC 120/230 V
18 W
Power Consumption (Typical)
25 Watt
Power Consumption Stand by / Sleep
0.34 Watt
Dimensions & Weight Details
Without stand - width: 55 cm - depth: 7.1 cm - height: 32.9 cm , With stand - width: 55 cm - depth: 21.4 cm - height: 38.1 cm - weight: 5.4 kg
ENERGY STAR Certified
Limited warranty - 3 years , Limited warranty - backlight - 3 years
5 °C
35 °C
20 - 80%
