NEC MultiSync C551 C Series 55" 1920x1080 8ms VGA HDMI DisplayPort LED Large Format Display
Quicklinx: F1G4WS00 Mfr#: 60004238
  • 1080p
Its thin bezel and super slim design perfectly complements today's modern surroundings whilst multiple display inputs support flexibility and freedom. With fixing points conveniently located on the back of the screen, external equipment can be attached with seamless simplicity. Reasonable brightness levels offer visibility in controlled light surroundings. The professional haze filter is allowing excellent readability. Landscape and portrait capability matches the needs of both corporate huddle spaces and retail signage applications. With a built-in media player, the NEC C Series runs content directly from a USB drive or microSD card as a standalone solution. Futureproof connectivity handles input from multiple sources. Don't let technology impact design - get seamless integration with the NEC C Series!
  • Impressive Full HD LCD technology
    Eye-pleasing black levels and impressive contrast ratios for ergonomic viewing and less fatigue in conferencing scenarios.
  • Modern and slim design
    Robust yet elegant allowing for an unobtrusive integration into any application and environment.
  • All-in-one signage solution integrated
    The integrated mediaplayer for simple signage use supports easy content playback and management.
  • Mission-critical 24/7 ready operation
    The meticulous selection of industrial-grade components and careful design focused on demanding usage scenarios accompany an impressive and continuous viewer experience.
  • Ease of use and operation
    Smart installation, operation and maintenance functionality ensures accurate performance over the entire lifetime of the display saving time, effort and resources.
NEC MultiSync C551 C Series - 55" LED-backlit LCD display - for digital signage
LED-backlit LCD flat panel display
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/428569
Diagonal Class
55"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Max Number of Screens
100
Video Interface
HDMI
HDMI Ports Qty
3 ports
LAN
PC Interface
VGA (HD-15), DisplayPort
AMVA3
LCD Backlight Technology
Edge-lit LED
Image Aspect Ratio
16:9
TV Tuner
No tuner
Commercial Features
SNMP support
Speaker System
2 speakers
Supported Memory Cards
microSD, microSDHC
USB
Remote control
Energy Class
Class G
75 watt
Power Consumption (On mode)
91 W
Power Consumption Stand by
0.5 watt
Energy Consumption per Year
120 kWh
123.8 cm x 4.5 cm x 70.9 cm
18.8 kg
Environmental Standards
ENERGY STAR Qualified
3-year warranty
Energy Class
Class G
75 watt
91 W
91 kWh/1000h
120 kWh
Diagonal Class
55"
Commercial Use
Series
C Series
TV Tuner
No tuner
TV Tuner Presence
No
Sensors
Ambient light sensor (ALS), temperature sensor
Video Interface
HDMI
HDMI Ports Qty
3 ports
PC Interface
Modes
Portrait mode, landscape mode, Face-up Mode
123.8 cm
4.5 cm
70.9 cm
18.8 kg
Enclosure Colour
Display
LCD Display Technology
AMVA3
Resolution
1920 x 1080
Image Aspect Ratio
16:9
Edge-lit LED
Image Contrast Ratio
4000:1
Brightness
500 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Response Time
8 ms
Commercial Features
SNMP support
TileMatrix (10 x 10), automatic alarm e-mails, Crestron Connected Compatible, Scheduler, NaViSet Administrator 2, AMX NetLinx support, PJLink, Crestron Roomview support, OmniColor, designed for 24/7 operation
Video Wall
100
Stands & Mounts
Stand
Optional
Flat Panel Mount Interface
300 x 300 mm
Video Features
Supported Computer Resolutions
1920 x 1200 (WUXGA), 1024 x 768 (XGA), 800 x 600 (SVGA), 1280 x 768 (WXGA), 1280 x 1024 (SXGA), 1600 x 1200 (UXGA), 1280 x 960, 1280 x 720, 1360 x 768, 1680 x 1050 (WSXGA+), 1920 x 1080, 1440 x 900, 1280 x 800, 1400 x 1050
Media Player
Supported Video Formats
MPEG-4, WMV, MOV, FLV, MPG
Supported Audio Formats
MP3, WAV
Supported Pictures Formats
PNG, JPEG
microSD, microSDHC
USB Port
USB Ports Qty
1
Remote Control
Remote control
Audio System
Speaker System
2 speakers
Output Power / Total
20 watt
Speakers
2 x main channel speaker - 10 watt
Network & Internet Multimedia
LAN
LAN Protocol
Fast Ethernet
Connector Type
VGA input , DisplayPort input , 3 x HDMI input , 2 x audio input , LAN , Remote control input , RS-232 , USB 2.0 , Audio output , Remote control output
VGA cable
CSA, UL, TUV GS, VCCI, C-Tick, cUL, VESA DPMS, PSB, FCC, RoHS, CEC, EMC Class B, IP5X, IP2X
Sustainability Information
ENERGY STAR Certified
ENERGY STAR Version
7.0
0.5 watt
Limited warranty - 3 years ¦ Limited warranty - backlight - 3 years
20 - 80%
