Its thin bezel and super slim design perfectly complements today's modern surroundings whilst multiple display inputs support flexibility and freedom. With fixing points conveniently located on the back of the screen, external equipment can be attached with seamless simplicity. Reasonable brightness levels offer visibility in controlled light surroundings. The professional haze filter is allowing excellent readability. Landscape and portrait capability matches the needs of both corporate huddle spaces and retail signage applications. With a built-in media player, the NEC C Series runs content directly from a USB drive or microSD card as a standalone solution. Futureproof connectivity handles input from multiple sources. Don't let technology impact design - get seamless integration with the NEC C Series!
Impressive Full HD LCD technology
Eye-pleasing black levels and impressive contrast ratios for ergonomic viewing and less fatigue in conferencing scenarios. -
Modern and slim design
Robust yet elegant allowing for an unobtrusive integration into any application and environment. -
All-in-one signage solution integrated
The integrated mediaplayer for simple signage use supports easy content playback and management. -
Mission-critical 24/7 ready operation
The meticulous selection of industrial-grade components and careful design focused on demanding usage scenarios accompany an impressive and continuous viewer experience. -
Ease of use and operation
Smart installation, operation and maintenance functionality ensures accurate performance over the entire lifetime of the display saving time, effort and resources.
- NEC MultiSync C551 C Series - 55" LED-backlit LCD display - for digital signage
- Product Type
- LED-backlit LCD flat panel display
- Energy Label QR Code URL
- Https://eprel.ec.europa.eu/qr/428569
- Diagonal Class
- 55"
- Commercial Use
- Yes - digital signage
- Black
- Resolution
- 1920 x 1080
- Max Number of Screens
- 100
- Video Interface
- HDMI
- HDMI Ports Qty
- 3 ports
- Connectivity
- LAN
- PC Interface
- VGA (HD-15), DisplayPort
- Technology
- AMVA3
- LCD Backlight Technology
- Edge-lit LED
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Commercial Features
- SNMP support
- Speaker System
- 2 speakers
- Supported Memory Cards
- microSD, microSDHC
- USB
- Included Accessories
- Remote control
- Energy Class
- Class G
- 75 watt
- Power Consumption (On mode)
- 91 W
- Power Consumption Stand by
- 0.5 watt
- Energy Consumption per Year
- 120 kWh
- 123.8 cm x 4.5 cm x 70.9 cm
- 18.8 kg
- Environmental Standards
- ENERGY STAR Qualified
- 3-year warranty
- Product Type
- Energy Class
- Class G
- 75 watt
- 91 W
- Power Consumption SDR (On mode)
- 91 kWh/1000h
- 120 kWh
- Diagonal Class
- 55"
- Commercial Use
- Series
- C Series
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Sensors
- Ambient light sensor (ALS), temperature sensor
- Video Interface
- HDMI
- HDMI Ports Qty
- 3 ports
- PC Interface
- Modes
- Portrait mode, landscape mode, Face-up Mode
- 123.8 cm
- 4.5 cm
- 70.9 cm
- 18.8 kg
- Enclosure Colour
- Black
Display
- LCD Display Technology
- AMVA3
- Resolution
- 1920 x 1080
- 16:9
- Edge-lit LED
- Image Contrast Ratio
- 4000:1
- Brightness
- 500 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Response Time
- 8 ms
- SNMP support
- TileMatrix (10 x 10), automatic alarm e-mails, Crestron Connected Compatible, Scheduler, NaViSet Administrator 2, AMX NetLinx support, PJLink, Crestron Roomview support, OmniColor, designed for 24/7 operation
Video Wall
- 100
Stands & Mounts
- Stand
- Optional
- Flat Panel Mount Interface
- 300 x 300 mm
Video Features
- Supported Computer Resolutions
- 1920 x 1200 (WUXGA), 1024 x 768 (XGA), 800 x 600 (SVGA), 1280 x 768 (WXGA), 1280 x 1024 (SXGA), 1600 x 1200 (UXGA), 1280 x 960, 1280 x 720, 1360 x 768, 1680 x 1050 (WSXGA+), 1920 x 1080, 1440 x 900, 1280 x 800, 1400 x 1050
Media Player
- Supported Video Formats
- MPEG-4, WMV, MOV, FLV, MPG
- Supported Audio Formats
- MP3, WAV
- Supported Pictures Formats
- PNG, JPEG
- USB Port
- USB Ports Qty
- 1
Remote Control
- Remote control
Audio System
- Speaker System
- 2 speakers
- Output Power / Total
- 20 watt
- Speakers
- 2 x main channel speaker - 10 watt
Network & Internet Multimedia
- Connectivity
- LAN
- LAN Protocol
- Fast Ethernet
- Connector Type
- VGA input , DisplayPort input , 3 x HDMI input , 2 x audio input , LAN , Remote control input , RS-232 , USB 2.0 , Audio output , Remote control output
- Cables Included
- VGA cable
- CSA, UL, TUV GS, VCCI, C-Tick, cUL, VESA DPMS, PSB, FCC, RoHS, CEC, EMC Class B, IP5X, IP2X
Sustainability Information
- ENERGY STAR Certified
- ENERGY STAR Version
- 7.0
- 0.5 watt
- Limited warranty - 3 years , Limited warranty - backlight - 3 years
- 0 °C
- 40 °C
- 20 - 80%
