NEC ME382U WUXGA 3lcd 3800 Lumens Projector
Quicklinx: F5PCWS00 Mfr#: 60004598
Delivering reliable visual support for successful lectures and presentations, the compact multipurpose ME series delivers crisp projected images and natural colors to your classroom or meeting facility thanks to LCD technology.
  • Robust connectivity
    Equipped with a wide range of interfaces including HDMI, VGA, USB, and RJ-45, this projector offers versatile connectivity options for various multimedia devices, ensuring seamless integration into any setup.
  • High-quality imaging
    Featuring a WUXGA resolution of 1920 x 1200 and a contrast ratio of 16000:1, the projector delivers sharp, clear images with rich detail and vibrant colors, making it suitable for presentations and multimedia use.
  • Long-lasting performance
    With a lamp life cycle of up to 15,000 hours in economic mode, this projector offers extended usability and reduced maintenance, ensuring reliable performance over time.
  • Advanced projection features
    Incorporates Advanced AccuBlend technology, Eco-Mode technology, and Geometric Correction, among others, to provide superior image quality, energy efficiency, and flexibility in various environments.
  • Efficient network control
    Supports wired LAN connectivity and is compatible with Crestron RoomView, enabling easy management and control of the projector over a network, enhancing convenience for users.
NEC ME382U - LCD projector - LAN - white
LCD projector - 1080p
White
Built-in Devices
Speaker, keypad
Brightness
3800 ANSI lumens
Contrast Ratio
16000:1
Resolution
WUXGA (1920 x 1200)
Native Aspect Ratio
16:10
Bulb type
225 Watt
Bulb life cycle
Up to 10000 hour(s) - normal mode , Up to 15000 hour(s) - economic mode
Video Input
(NTSC 3.58, NTSC 4.43, PAL, PAL-N, PAL-M, PAL 60, SECAM), LAN
Video Modes
480p, 480i, 576i, 576p, 720p, 1080i, 1080p
Speakers
Speaker(s) - integrated
295 Watt
34.5 cm x 10.46 cm x 26.1 cm
3.5 kg
3-year warranty
Built-in Devices
Speaker, keypad
Ethernet
Enclosure Colour
White
Projector
Brightness
3800 ANSI lumens
Contrast Ratio
16000:1
Image Size
76 cm - 762 cm
Projection Distance
0.8 m - 12.9 m
Throw Ratio
1.2 - 2.1:1
Resolution
WUXGA - WUXGA (1920 x 1200) (native) / 3840 x 2160 (resized)
Native Aspect Ratio
16:10
Max Sync Rate (V x H)
120 Hz x 100 kHz
Bulb type
225 Watt
Bulb life cycle
Controls & Adjustments
Zoom, focus, keystone correction
Advanced AccuBlend technology, AutoSense technology, USB Viewer, auto power on, Carbon Savings Meter, Cornerstone, Eco-Mode technology, sleep timer, Virtual Remote, wall colour correction, Crestron RoomView, Direct Power Off, Geometric Correction, High-bandwidth Digital Content Protection System (HDCP), Quick On/Off
Lens
Focus Type
Manual
Lens Aperture
F/1.5-2.08
Zoom Type
Manual
Zoom Factor
1.6x
Keystone Correction Direction
Horizontal, vertical
Vertical Keystone Correction
-30 / +30
Horizontal Keystone Correction
-20 / +20
Video Input
TV System
Video Interfaces
VGA, HDMI, component video, composite video
Video Modes
LAN and Wireless Image Transferring Protocols
Wired LAN
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
16 Watt
Speakers
1 x mixed channel
1 x VGA / component video input - 15 pin HD D-Sub (HD-15) , 1 x audio line-in - mini-phone stereo 3.5 mm , 2 x HDMI - 19 pin HDMI Type A , 1 x USB - 4 pin USB Type B , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x composite video input - RCA , 1 x audio line-in - RCA x 2 , 1 x network - RJ-45 , 1 x USB - 4 pin USB Type A , 1 x serial RS-232 - 9 pin D-Sub (DB-9)
Wireless remote control, battery for remote control
Security Features
Security Slot Type
Kensington security slot
EAC, ERP, RoHS, WEEE
Power Source
AC
295 Watt
Power Consumption Stand by
0.5 Watt
34.5 cm
10.46 cm
26.1 cm
3.5 kg
Limited warranty - 3 years , Limited warranty - lamp - 6 months / 1000 hours
5 °C
20 - 80%
Sound Emission
37 dB
29 dB
