Easy to use, the ME series projectors using LCD technology provide all the essential features that you need to connect with your audience. The NEC ME301X is ideal for education and small business environments that need essential features, including bright colorful images, automatic technologies and eco-friendly appeal.
Variable audio out
Adjusts the volume of an external speaker system using the projector's remote control. -
Dual HDMI inputs
Ensure quick switching between presentations and allows for simultaneous digital connections of high-definition sources, such as Blu-ray players, cable boxes, satellite receivers and computers. -
Cornerstone correction
Allows for horizontal, vertical and diagonal image correction for aligned images even when the projector is set up at an angle to the screen. -
Built-in wall color correction
Presets provide for adaptive color tone correction to display properly on non-white surfaces.
- NEC ME301X - LCD projector - portable - LAN
- LCD projector
- Built-in Devices
- Speaker
- Brightness
- 3000 lumens
- Contrast Ratio
- 12000:1
- Resolution
- XGA (1024 x 768)
- Native Aspect Ratio
- 4:3
- Bulb type
- 240 Watt
- Bulb life cycle
- Up to 4000 hour(s) - normal mode , Up to 9000 hour(s) - economic mode
- Video Input
- RGB, composite video, component video (NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60), LAN
- Video Modes
- 480p, 720p, 1080i, 1080p, 480i, 576i, 576p
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V (50/60 Hz)
- 286 Watt
- 36.8 cm x 29.2 cm x 10.8 cm
- 2.9 kg
- 2-year warranty
- LCD projector
- Built-in Devices
- Speaker
- Networking
- Ethernet
Projector
- Brightness
- 3000 lumens
- Contrast Ratio
- 12000:1
- Image Size
- 76 cm - 762 cm
- Projection Distance
- 0.6 m - 13.8 m
- Throw Ratio
- 1.3 - 2.2:1
- Resolution
- XGA - XGA (1024 x 768) (native) / 1920 x 1200 (resized)
- 4:3
- Max Sync Rate (V x H)
- 120 Hz x 153 kHz
- Bulb type
- 240 Watt
- Bulb life cycle
- Controls & Adjustments
- Keystone correction
- AutoSense technology, Advanced AccuBlend technology, Micro Lens Array (MLA) Technology, wall colour correction, Crestron RoomView, DICOM Simulation Mode, auto power on, USB Viewer, Cornerstone, Carbon Savings Meter, Eco Mode, Virtual Remote, sleep timer
Lens
- Focus Type
- Manual
- Lens Aperture
- F/1.7-2.1
- Zoom Type
- Manual
- Zoom Factor
- 1.7x
- Keystone Correction Direction
- Horizontal, vertical
- Vertical Keystone Correction
- -30 / +30
- Horizontal Keystone Correction
- -30 / +30
Video Input
- TV System
- NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, component video, composite video
- Video Modes
- LAN and Wireless Image Transferring Protocols
- Wired LAN
Speakers
- Integrated
- Sound Output Mode
- Mono
- Output Power / Channel
- 20 Watt
- Speakers
- 1 x mixed channel
- 1 x VGA / component video input - 15 pin HD D-Sub (HD-15) , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 2 x HDMI - 19 pin HDMI Type A , 1 x composite video input - RCA , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-in - RCA x 2 , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x serial RS-232 - 9 pin D-Sub (DB-9) (management) , 1 x network - RJ-45 , 1 x USB - 4 pin USB Type A , 1 x USB 2.0 - 4 pin USB Type B
- Included Accessories
- Wireless remote control
- Cables Included
- 1 x VGA cable
- NOM, ICES-003 Class B, UL 60950-1, FCC Part 15 Class B, UL/CSA60950-1
- Power Source
- AC
- Voltage Required
- 286 Watt
- Power Consumption Stand by
- 1.9 Watt
- Software Included
- NaViSet Administrator 2, NEC MultiPresenter
- 36.8 cm
- 29.2 cm
- 10.8 cm
- 2.9 kg
- Limited warranty - 2 years , Limited warranty - lamp - 1 year / 500 hours
- 5 °C
- 40 °C
- 20 - 80% (non-condensing)
- Sound Emission
- 35 dB
- Sound Emission (Economic Mode)
- 29 dB
