NEC M402H DLP 4000 Lumens Projector
Quicklinx: 9LPSWS00 Mfr#: 60003692
With 1080p resolution and 10000:1 contrast, the M402H delivers perfect image quality for very detailed content as well as high quality movies. With highly efficient and innovative ECO features, a sealed DLP light engine, long lamp life and low power consumption, this projector is virtually maintenance free and offers an impressively low cost of ownership without compromising on quality and flexibility. Innovative ECO functions help to significantly reduce power consumption.
  • High-definition visuals
    Experience the clarity and detail of Full HD 1080p resolution, making every presentation come to life with vivid colors and sharp images. The native 16:9 aspect ratio ensures cinema-quality video display, perfect for multimedia presentations.
  • Versatile connectivity
    Equipped with a wide range of interfaces including HDMI, VGA, composite video, and audio inputs, this projector offers flexible connection options to suit a variety of multimedia devices. The inclusion of USB and network interfaces further enhances its adaptability for different presentation environments.
  • Long-lasting performance
    With a lamp life cycle of up to 3500 hours in normal mode and 8000 hours in economic mode, this projector is designed for durability and extended use. This ensures reliable performance over time, reducing the need for frequent lamp replacements.
  • Enhanced audio experience
    Integrated 20 W speaker provides powerful sound output, ensuring that your presentations are not only visually captivating but also audibly clear. This feature allows for an all-encompassing presentation experience without the need for external speakers.
  • 3D ready
    Dive into immersive presentations with the 3D ready feature, offering a new dimension of engagement for your audience. This technology brings your content to life, making it more interactive and impactful.
NEC M402H - DLP projector - 3D - LAN
DLP projector - 1080p
3D Capable
Yes (3D glasses sold separately)
Built-in Devices
Speaker
Microdisplay
DMD Chip
Brightness
4000 ANSI lumens
Contrast Ratio
10000:1
Resolution
Full HD (1920 x 1080)
Native Aspect Ratio
16:9
Bulb type
270 Watt
Bulb life cycle
Up to 3500 hour(s) - normal mode , Up to 8000 hour(s) - economic mode
Video Input
RGB, composite video, component video (NTSC, SECAM, PAL, PAL-M, NTSC 4.43, PAL 60), LAN
Supported Memory Cards
SD Memory Card
Video Modes
480p, 720p, 1080i, 1080p, 480i, 576i, 576p
Speakers
Speaker(s) - integrated
278 Watt
36.79 cm x 29.13 cm x 10.75 cm
3.7 kg
3-year warranty
3D Capable
Built-in Devices
Speaker
Ethernet
Projector
Microdisplay
DMD Chip
Brightness
4000 ANSI lumens
Contrast Ratio
10000:1
Image Size
76.2 cm - 762 cm
Projection Distance
0.74 m - 14.08 m
Throw Ratio
1.2 - 2.1:1
Resolution
Full HD - Full HD (1920 x 1080) (native) / 1920 x 1200 (resized)
Native Aspect Ratio
16:9
Max Sync Rate (V x H)
120 Hz x 100 kHz
Bulb type
270 Watt
Bulb life cycle
Controls & Adjustments
Volume, input select, keystone correction, zoom, aspect control, off timer
JPEG photo playback, wall colour correction, DLP 3D Ready, Auto Vertical Keystone, Crestron RoomView, Intelligent Power Management, DICOM Simulation Mode, ImageCare Technology, auto power on, USB Viewer, ambient light sensor, Carbon Savings Meter, Virtual Remote, Auto Eco Mode, High Altitude Mode
Lens
Focus Type
Manual
Lens Aperture
F/2.4-3.2
Zoom Type
Manual
Zoom Factor
1.7x
Keystone Correction Direction
Horizontal, vertical
Vertical Keystone Correction
-30 / +30
Horizontal Keystone Correction
-25 / +25
Video Input
TV System
Analogue video Signal
Video Interfaces
VGA, HDMI, composite video
Video Modes
SD Memory Card
LAN and Wireless Image Transferring Protocols
Wired LAN
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
20 Watt
Speakers
1 x mixed channel
1 x VGA / component video input - 15 pin HD D-Sub (HD-15) , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 2 x HDMI input - 19 pin HDMI Type A , 1 x composite video input - RCA , 1 x audio line-in - RCA x 2 , 1 x microphone input - mini-phone stereo 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x serial RS-232 - 9 pin D-Sub (DB-9) , 1 x network - RJ-45 , 1 x USB - 4 pin USB Type B , 1 x USB 2.0 - 4 pin USB Type A , 1 x 3D Sync out - 3 PIN mini-DIN , 1 x audio line-in - mini-phone stereo 3.5 mm
Carrying case, wireless remote control
1 x VGA cable
Security Features
Security lock slot (cable lock sold separately), password protection, security bar, security label, keypad lock
RoHS, GOST-R, ErP Ready, EAC
Power Source
AC
278 Watt
Power Consumption Stand by
0.4 Watt
Software Included
NaViSet Administrator 2
36.79 cm
29.13 cm
10.75 cm
3.7 kg
EMEA warranty - 3 years , Limited warranty - lamp - 6 months / 1000 hours
5 °C
20 - 80% (non-condensing)
Sound Emission
39 dB
33 dB
